Сыпятся ошибки debmes ClockChime.onNewMinut...
maked0nski
Сообщение maked0nski »
Постоянно сыпятся куча ошибок
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":0,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":0.203,"namelookup_time":1.0e-6,"connect_time":0,"pretransfer_time":0,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"","certinfo":[],"primary_port":0,"local_ip":"","local_port":0}
11:21:01 0.93268200 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
Failed to connect to 127.0.0.1 port 80: Connection refused
11:22:01 0.20507200 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":0,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":0.202,"namelookup_time":1.0e-6,"connect_time":0,"pretransfer_time":0,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"","certinfo":[],"primary_port":0,"local_ip":"","local_port":0}
11:23:01 0.46851900 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
11:24:45 0.60847600 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
Operation timed out after 45006 milliseconds with 0 bytes received
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.006,"namelookup_time":1.0e-6,"connect_time":1.0e-6,"pretransfer_time":1.0e-6,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":56173}
11:25:45 0.64791000 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.006,"namelookup_time":1.0e-6,"connect_time":1.0e-6,"pretransfer_time":1.0e-6,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":56175}
11:26:45 0.68034300 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.006,"namelookup_time":1.0e-6,"connect_time":1.0e-6,"pretransfer_time":1.0e-6,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":56176}
11:27:45 0.71377700 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.006,"namelookup_time":1.0e-6,"connect_time":1.0e-6,"pretransfer_time":1.0e-6,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":56177}
11:28:45 0.74021000 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
Operation timed out after 45007 milliseconds with 0 bytes received
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.007,"namelookup_time":1.0e-6,"connect_time":1.0e-6,"pretransfer_time":1.0e-6,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":56178}
11:29:45 0.77164400 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.006,"namelookup_time":1.0e-6,"connect_time":1.0e-6,"pretransfer_time":1.0e-6,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":56179}
11:30:45 0.80007700 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.006,"namelookup_time":1.0e-6,"connect_time":1.0e-6,"pretransfer_time":1.0e-6,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":56181}
11:31:45 0.84451200 GetURL to http://127.0.0.1:80/objects/?object=Clo ... nNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.006,"namelookup_time":1.0e-6,"connect_time":0.015,"pretransfer_time":0.015,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":56182}
за пару дней папка debmes 280 Мб весит. Подскажите куда копать. И пропадает доступ что лакально что удаленно. перезапускаю Мажор работает, через некоторое время снова доступа нету
slgeo
Re: Сыпятся ошибки debmes ClockChime.onNewMinut...
Сообщение slgeo »
Система какая? Скорее всего апач падает. Надо его логи смотреть.
CONNECT
maked0nski
Пока настраиваю и тестирую на винде 7 64
Обновлены сервера апач и пхп по этой ссылке https://majordomo.smartliving.ru/forum/ ... 109#p73004
лог апач:
[Mon Mar 05 19:08:38.159946 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 19:08:38.160946 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 19:11:13.216815 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 19:22:39.419063 2018] [core:error] [pid 2904:tid 964] (20024)The given path is misformatted or contained invalid characters: [client 73.158.127.66:55272] AH00127: Cannot map GET /w00tw00t.at.blackhats.romanian.anti-sec:) HTTP/1.1 to file
[Mon Mar 05 19:23:05.785572 2018] [php7:error] [pid 2904:tid 896] [client 73.158.127.66:37108] script 'C:/_majordomo/htdocs/scripts/setup.php' not found or unable to stat
[Mon Mar 05 19:31:11.978380 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 19:51:13.736117 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 20:11:11.795434 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 21:01:07.078656 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 21:11:13.898333 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 21:31:13.264933 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Mar 05 21:51:12.902549 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:22.288710 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:22.289710 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:22.290710 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:22.291710 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:22.291710 2018] [mpm_winnt:error] [pid 2904:tid 304] AH00326: Server ran out of threads to serve requests. Consider raising the ThreadsPerChild setting
[Tue Mar 06 11:23:22.816740 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:23.231764 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:23.696791 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:24.104814 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:24.806854 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:23:25.749908 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:46:45.800986 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:46:45.801986 2018] [mpm_winnt:warn] [pid 2904:tid 304] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Tue Mar 06 11:51:45.114056 2018] [ssl:warn] [pid 2580:tid 232] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue Mar 06 11:51:45.144056 2018] [ssl:warn] [pid 2580:tid 232] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Tue Mar 06 11:51:45.364056 2018] [core:warn] [pid 2580:tid 232] AH00098: pid file C:/_majordomo/server/Apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Mar 06 11:51:45.476057 2018] [ssl:warn] [pid 2580:tid 232] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Tue Mar 06 11:51:45.476057 2018] [ssl:warn] [pid 2580:tid 232] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue Mar 06 11:51:45.476057 2018] [ssl:warn] [pid 2580:tid 232] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Tue Mar 06 11:51:45.720060 2018] [mpm_winnt:notice] [pid 2580:tid 232] AH00455: Apache/2.4.18 (Win32) OpenSSL/1.0.2f PHP/7.2.2 configured -- resuming normal operations
[Tue Mar 06 11:51:45.720060 2018] [mpm_winnt:notice] [pid 2580:tid 232] AH00456: Server built: Jan 28 2016 09:58:25
[Tue Mar 06 11:51:45.720060 2018] [core:notice] [pid 2580:tid 232] AH00094: Command line: 'C:\\_majordomo\\server\\Apache\\bin\\Apache.exe -d C:/_majordomo/server/Apache -f C:\\_majordomo\\\\server\\apache\\conf\\\\httpd.conf'
[Tue Mar 06 11:51:45.720060 2018] [mpm_winnt:notice] [pid 2580:tid 232] AH00418: Parent: Created child process 2892
[Tue Mar 06 11:51:46.322062 2018] [ssl:warn] [pid 2892:tid 248] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue Mar 06 11:51:46.322062 2018] [ssl:warn] [pid 2892:tid 248] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Tue Mar 06 11:51:46.552063 2018] [ssl:warn] [pid 2892:tid 248] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Tue Mar 06 11:51:46.552063 2018] [ssl:warn] [pid 2892:tid 248] AH01906: main-serveur:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue Mar 06 11:51:46.552063 2018] [ssl:warn] [pid 2892:tid 248] AH01909: main-serveur:443:0 server certificate does NOT include an ID which matches the server name
[Tue Mar 06 11:51:46.742063 2018] [mpm_winnt:notice] [pid 2892:tid 248] AH00354: Child: Starting 64 worker threads.
[Tue Mar 06 12:52:28.697616 2018] [mpm_winnt:warn] [pid 2892:tid 1004] (OS 64)Указанное сетевое имя более недоступно. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
slgeo
Сообщение slgeo »
Ну, пробуй искать по этой ошибке
CONNECT
maked0nski
slgeo писал(а):Ну, пробуй искать по этой ошибке
Спасибо. Пока пол часа - полет нормальный
maked0nski
Работает стабильно. Ошибок нет. Еще раз спасибо !!!
