Лог Apache2
andrey1509
Лог Apache2
Сообщение andrey1509 »
Доброго всем времени.
Может кто подскажет как исправить ошибку.
В Apache2 в error.log при обращении к сайту сыпятся ошибки.
[Thu Aug 31 21:14:32 2017] [error] [client 192.168.1.33] PHP Warning:  require(./modules/devices/system_checkstate.php): failed to open stream: No such file or directory in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:14:32 2017] [error] [client 192.168.1.33] PHP Fatal error:  require(): Failed opening required './modules/devices/system_checkstate.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:19:34 2017] [error] [client 192.168.1.33] PHP Warning:  require(./modules/devices/system_checkstate.php): failed to open stream: No such file or directory in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:19:34 2017] [error] [client 192.168.1.33] PHP Fatal error:  require(): Failed opening required './modules/devices/system_checkstate.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:24:33 2017] [error] [client 192.168.1.33] PHP Warning:  require(./modules/devices/system_checkstate.php): failed to open stream: No such file or directory in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
[Thu Aug 31 21:24:33 2017] [error] [client 192.168.1.33] PHP Fatal error:  require(): Failed opening required './modules/devices/system_checkstate.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/modules/objects/objects.class.php(530) : eval()'d code on line 51, referer: http://cubie/menu.html
Google- в помощь ни чего не дала.
Debian Linux 7,Linux 3.2.0-4-686-pae on i686
Intel(R) Celeron(R) CPU 1.70GHz, 1 cores
Re: Лог Apache2
Не хватает файла './modules/devices/system_checkstate.php' -- он должен был установиться при обновлении, но если что возьмите отсюда:
https://github.com/sergejey/majordomo/r ... kstate.php
andrey1509
Re: Лог Apache2
sergejey писал(а):Не хватает файла './modules/devices/system_checkstate.php' -- он должен был установиться при обновлении, но если что возьмите отсюда:
Спасибо все заработало после обновления всей системы.
