Проблемы со сном?
C_3AXAPOB
Проблемы со сном?
Сообщение C_3AXAPOB »
Собрал датчик:
- Ардуино про мини 3.3 v
- Один геркон
- Питание от батарейки: + пин А0 - пин GND
C вот таким скетчем:
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
#include <MySensors.h>
#define SKETCH_NAME "Door sensor (battery)"
#define SKETCH_MAJOR_VER "1"
#define SKETCH_MINOR_VER "0"
#define PRIMARY_CHILD_ID 3
#define SECONDARY_CHILD_ID 4
#define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
#define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
#if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
#error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
#endif
#if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
#error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
#endif
#if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
#error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
#endif
#if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
#error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
#endif
// Change to V_LIGHT if you use S_LIGHT in presentation below
MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
void setup()
  // Setup the buttons
  pinMode(PRIMARY_BUTTON_PIN, INPUT);
  pinMode(SECONDARY_BUTTON_PIN, INPUT);
  // Activate internal pull-ups
  digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
  digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
void presentation()
  // Send the sketch version information to the gateway and Controller
  sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
  // Register binary input sensor to sensor_node (they will be created as child devices)
  // You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage.
  // If S_LIGHT is used, remember to update variable type you send in. See "msg" above.
  present(PRIMARY_CHILD_ID, S_DOOR);
  present(SECONDARY_CHILD_ID, S_DOOR);
// Loop will iterate on changes on the BUTTON_PINs
void loop()
  uint8_t value;
  static uint8_t sentValue=2;
  static uint8_t sentValue2=2;
  // Short delay to allow buttons to properly settle
  sleep(5);
  value = digitalRead(PRIMARY_BUTTON_PIN);
  if (value != sentValue) {
    // Value has changed from last transmission, send the updated value
    send(msg.set(value==HIGH));
    sentValue = value;
  value = digitalRead(SECONDARY_BUTTON_PIN);
  if (value != sentValue2) {
    send(msg2.set(value==HIGH));
    sentValue2 = value;
  // Sleep until something happens with the sensor
  sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
Всё работает, датчик срабатывает, гейт читает, МЖД реагирует.
Но время работы полдня максимум.
Есть подозрение что датчик не спит. Что посоветуете?
ipz
Re: Проблемы со сном?
Сообщение ipz »
C_3AXAPOB писал(а): - Питание от батарейки: + пин А0 - пин GND
А так можно было?
На Pro-mini же есть и Vcc и Raw.
Опять же батарейка неизвестной емкости - я когда свои 18650 прогнал через opus - был сильно удивлен наличием почти мертвых. Не ожидал просто.
На сайте Mysensor отдельная статья была - как сократить потребление (убрать светодиоды, перерезать дорожку у линейного стабилизатора напряжения)
Про сон ничего не скажу, сон по прерыванию не использовал...
DimSun75
Сообщение DimSun75 »
C_3AXAPOB писал(а): Всё работает, датчик срабатывает, гейт читает, МЖД реагирует.
Первый совет: тестером проверить реальное потребление. Только так и можно сделать вывод спит или нет, и почему жрет батарейку
C_3AXAPOB
Тестера нет. Предполагаю, что в скетче какая-то проблема. Он заточен под два датчика но я подключил только один, может поэтому не спит?
DimSun75
C_3AXAPOB писал(а):Тестера нет. Предполагаю, что в скетче какая-то проблема. Он заточен под два датчика но я подключил только один, может поэтому не спит?
Тестер при строительстве умного дома вещь просто необходимая. Если вывод в воздухе, то теоретически может быть что угодно. Можно попробовать выкинуть из sleep второе прерывание. как-то так должно быть:
sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
DimSun75
C_3AXAPOB писал(а):Собрал датчик:
А это как, недопонял
C_3AXAPOB
Как тут написано https://www.mysensors.org/build/battery
Use a 1MΩ (R1) and 470KΩ (R2) resistor in series, connected to the positive terminal on the battery and ground and then connected the tap point to the A0 input on the CPU.
ipz
Сообщение ipz »
Это написано про делитель напряжения, для измерения напряжения на батарейке.
Делитель напряжения, даже если Вы его правильно подключите, тоже будет съедать батарейку. Но нужно тогда и в скетч добавлять считывание A0.
Лучше мерить используя регистры Atmegа. У Ивана в примерах батареечной ноды это есть.
Если ваш аккумулятор/батарейки выдает меньше 3,7 (по-моему), то плюс надо подключить к Vcc. Если больше, то к Raw (но в этом случае, батарейка будет быстро заканчиваться из-за того что регулятор напряжения потребляет 0,22mA)
Последний раз редактировалось ipz Ср мар 01, 2017 12:32 am, всего редактировалось 1 раз.
C_3AXAPOB
Куда нужно правильно подключить батарейку?
ipz
Сообщение ipz »
Написал выше.
Чем вы запитываете ноду?
