<?php
* Z-Wave
* Zwave
* @package project
* @author Serge J. <
[email protected]>
* @copyright
http://www.atmatic.eu/ (c)
* @version 0.1 (wizard, 17:05:52 [May 30, 2013])
class zwave extends module {
* zwave
* Module class constructor
* @access private
function zwave() {
$this->name="zwave";
$this->title="<#LANG_MODULE_ZWAVE#>";
$this->module_category="<#LANG_SECTION_DEVICES#>";
$this->checkInstalled();
* saveParams
* Saving module parameters
* @access public
function saveParams($data=0) {
$p=array();
if (IsSet($this->id)) {
$p["id"]=$this->id;
if (IsSet($this->view_mode)) {
$p["view_mode"]=$this->view_mode;
if (IsSet($this->edit_mode)) {
$p["edit_mode"]=$this->edit_mode;
if (IsSet($this->data_source)) {
$p["data_source"]=$this->data_source;
if (IsSet($this->tab)) {
$p["tab"]=$this->tab;
return parent::saveParams($p);
* getParams
* Getting module parameters from query string
* @access public
function getParams() {
global $id;
global $mode;
global $view_mode;
global $edit_mode;
global $data_source;
global $tab;
if (isset($id)) {
$this->id=$id;
if (isset($mode)) {
$this->mode=$mode;
if (isset($view_mode)) {
$this->view_mode=$view_mode;
if (isset($edit_mode)) {
$this->edit_mode=$edit_mode;
if (isset($data_source)) {
$this->data_source=$data_source;
if (isset($tab)) {
$this->tab=$tab;
* Run
* Description
* @access public
function run() {
global $session;
$out=array();
if ($this->action=='admin') {
$this->admin($out);
$this->usual($out);
if (IsSet($this->owner->action)) {
$out['PARENT_ACTION']=$this->owner->action;
if (IsSet($this->owner->name)) {
$out['PARENT_NAME']=$this->owner->name;
$out['VIEW_MODE']=$this->view_mode;
$out['EDIT_MODE']=$this->edit_mode;
$out['MODE']=$this->mode;
$out['ACTION']=$this->action;
$out['DATA_SOURCE']=$this->data_source;
$out['TAB']=$this->tab;
if (IsSet($this->location_id)) {
$out['IS_SET_LOCATION_ID']=1;
if (IsSet($this->device_id)) {
$out['IS_SET_DEVICE_ID']=1;
if (IsSet($this->uniq_id)) {
$out['IS_SET_UNIQ_ID']=1;
if ($this->single_rec) {
$out['SINGLE_REC']=1;
$this->data=$out;
$p=new parser(DIR_TEMPLATES.$this->name."/".$this->name.".html", $this->data, $this);
$this->result=$p->result;
* BackEnd
* Module backend
* @access public
function admin(&$out) {
if (isset($this->data_source) && !$_GET['data_source'] && !$_POST['data_source']) {
$out['SET_DATASOURCE']=1;
$this->getConfig();
$out['ZWAVE_API_URL']=$this->config['ZWAVE_API_URL'];
if (!$out['ZWAVE_API_URL']) {
$out['ZWAVE_API_URL']='http://';
$out['ZWAVE_API_USERNAME']=$this->config['ZWAVE_API_USERNAME'];
$out['ZWAVE_API_PASSWORD']=$this->config['ZWAVE_API_PASSWORD'];
$out['ZWAVE_API_AUTH']=$this->config['ZWAVE_API_AUTH'];
$out['ZWAVE_API_RESET']=(int)$this->config['ZWAVE_API_RESET'];
if ($this->view_mode=='update_settings') {
global $zwave_api_url;
global $zwave_api_username;
global $zwave_api_password;
global $zwave_api_auth;
global $zwave_api_reset;
if (!preg_match('/\/$/', $zwave_api_url)) {
$zwave_api_url=$zwave_api_url.'/';
$this->config['ZWAVE_API_URL']=$zwave_api_url;
$this->config['ZWAVE_API_USERNAME']=$zwave_api_username;
$this->config['ZWAVE_API_PASSWORD']=$zwave_api_password;
$this->config['ZWAVE_API_AUTH']=(int)$zwave_api_auth;
$this->config['ZWAVE_API_RESET']=(int)$zwave_api_reset;
$this->saveConfig();
$this->redirect("?");
$out['API_STATUS']=$this->connect();
if ($this->view_mode=='rescan') {
$this->scanNetwork();
if ($this->data_source=='zwave_devices' || $this->data_source=='') {
if ($this->view_mode=='' || $this->view_mode=='search_zwave_devices') {
$this->search_zwave_devices($out);
if ($this->view_mode=='edit_zwave_devices') {
$this->edit_zwave_devices($out, $this->id);
if ($this->view_mode=='delete_zwave_devices') {
$this->delete_zwave_devices($this->id);
$this->redirect("?data_source=zwave_devices");
if ($this->data_source=='zwave_properties') {
if ($this->view_mode=='' || $this->view_mode=='search_zwave_properties') {
$this->search_zwave_properties($out);
* Title
* Description
* @access public
function connect() {
return include_once(DIR_MODULES.$this->name.'/zwave_connect.inc.php');
* Title
* Description
* @access public
function scanNetwork() {
$data=$this->apiCall('/ZWaveAPI/Data/0');
$devices=array();
for($i=1;$i<500;$i++) {
if (isset($data->devices->{$i})) {
$device=$data->devices->{$i};
$device->id=$i;
$device->type=$device->data->deviceTypeString->value;
if ($device->type=='Static PC Controller') {
continue;
//echo $device->data->NodeId->value."<hr>";
//var_dump($device->instances->{'0'}->commandClasses);
//echo "<hr>";
if ($device->instances->{'0'}->commandClasses->{'119'}->data->nodename->value!='') {
$device->title=$device->type.' '.$i.' ('.$device->instances->{'0'}->commandClasses->{'119'}->data->nodename->value.')';
$device->title=$device->type.' '.$i;
if (isset($device->instances->{'1'})) {
$device->multi_instance=1;
for($k=0;$k<50;$k++) {
if (isset($device->instances->{"$k"})) {
$instance = (object) array_merge((array) $device, (array) $device->instances->{"$k"});
$instance->instance=$k;
if ($device->multi_instance) {
$instance->title.=' (inst.: '.$k.')';
$devices[]=$instance;
break;
continue;
$seen_devices=array();
$total=count($devices);
//echo "Total: ".$total."<br>";
for($i=0;$i<$total;$i++) {
//echo $i.' '.$devices[$i]->title."<br>";
$rec=SQLSelectOne("SELECT * FROM zwave_devices WHERE NODE_ID='".$devices[$i]->id."' AND INSTANCE_ID='".$devices[$i]->instance."'");
$rec['NODE_ID']=$devices[$i]->id;
$rec['INSTANCE_ID']=$devices[$i]->instance;
$rec['DEVICE_TYPE']=$devices[$i]->data->genericType->value;
if (!$rec['TITLE']) {
$rec['TITLE']=$devices[$i]->title;
$all_classes=array();
for($k=0;$k<255;$k++) {
if (isset($devices[$i]->commandClasses->{"$k"}->data)) {
$all_classes[]=$k;
if ($all_classes[0]) {
$rec['ALL_CLASSES']='|'.implode('|', $all_classes).'|';
$rec['ALL_CLASSES']='';
if (isset($devices[$i]->commandClasses->{'32'}->data)) {
$rec['CLASS_BASIC']=1;
$rec['CLASS_BASIC']=0;
if (isset($devices[$i]->commandClasses->{'48'}->data)) {
$rec['CLASS_SENSOR_BINARY']=1;
$rec['CLASS_SENSOR_BINARY']=0;
if (isset($devices[$i]->commandClasses->{'49'}->data)) {
$rec['CLASS_SENSOR_MULTILEVEL']=1;
$rec['CLASS_SENSOR_MULTILEVEL']=0;
if (isset($devices[$i]->commandClasses->{'64'}->data)) {
$rec['CLASS_THERMOSTAT']=1;
$rec['CLASS_THERMOSTAT']=0;
if (isset($devices[$i]->commandClasses->{'37'}->data)) {
$rec['CLASS_SWITCH_BINARY']=1;
$rec['CLASS_SWITCH_BINARY']=0;
if (isset($devices[$i]->commandClasses->{'38'}->data)) {
$rec['CLASS_SWITCH_MULTILEVEL']=1;
$rec['CLASS_SWITCH_MULTILEVEL']=0;
if (isset($devices[$i]->commandClasses->{'50'}->data)) {
$rec['CLASS_METER']=1;
$rec['CLASS_METER']=0;
if (isset($devices[$i]->commandClasses->{'112'}->data)) {
$rec['CLASS_CONFIG']=1;
$rec['CLASS_CONFIG']=0;
if (isset($devices[$i]->commandClasses->{'113'}->data)) {
$rec['CLASS_SENSOR_NOTIFICATION']=1;
$rec['CLASS_SENSOR_NOTIFICATION']=0;
if (isset($devices[$i]->commandClasses->{'128'}->data)) {
$rec['CLASS_BATTERY']=1;
$rec['CLASS_BATTERY']=0;
if (isset($devices[$i]->commandClasses->{'156'}->data)) {
$rec['CLASS_SENSOR_ALARM']=1;
$rec['CLASS_SENSOR_ALARM']=0;
if (is_object($devices[$i]->commandClasses->{'45'}) || is_object($devices[$i]->commandClasses->{'43'})) {
$rec['CLASS_SCENE_CONTROLLER']=1;
$rec['CLASS_SCENE_CONTROLLER']=0;
if (!$rec['ID']) {
$rec['ID']=SQLInsert('zwave_devices', $rec);
SQLUpdate('zwave_devices', $rec);
$seen_devices[]=$rec['ID'];
$this->pollDevice($rec['ID'], $devices[$i]);
global $remove_not_found;
if (count($seen_devices)>0 && $remove_not_found) {
$devices=SQLSelect("SELECT ID FROM zwave_devices WHERE ID NOT IN (".implode(',', $seen_devices).")");
$this->delete_zwave_devices($devices[$i]['ID']);
return $data->updateTime;
* Title
* Description
* @access public
function setProperty($property_id, $value) {
$rec=SQLSelectOne("SELECT * FROM zwave_properties WHERE ID='".$property_id."'");
$device=SQLSelectOne("SELECT * FROM zwave_devices WHERE ID='".$rec['DEVICE_ID']."'");
if ($rec['TITLE']=='Basic' && $device['CLASS_BASIC']) {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[32].Set('.$value.')');
if ($rec['TITLE']=='EVENT' && $device['CLASS_SENSOR_NOTIFICATION']) {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[113].Set('.$value.')');
if ($rec['TITLE']=='Level') {
if ($device['CLASS_SWITCH_BINARY']) {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[37].Set('.$value.')');
if ($device['CLASS_SWITCH_MULTILEVEL']) {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[38].Set('.$value.')');
if ($rec['TITLE']=='LevelDuration command (level, duration)') {
$tmp=explode(',', $value);
$tmp[0]=(int)trim($tmp[0]);
$tmp[1]=(int)trim($tmp[1]);
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[38].Set('.$tmp[0].','.$tmp[1].')');
if ($device['CLASS_THERMOSTAT'] && $rec['TITLE']=='Thermostat mode') {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].']');
$mode='';
$av_modes=$data->commandClasses->{"64"}->data;
for($i=0;$i<255;$i++) {
if (isset($av_modes->{"$i"}->modename)) {
if ($av_modes->{"$i"}->modename->value==$value) {
$mode=$i;
break;
if ($mode) {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[64].Set('.$mode.')');
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[64].Set('.$value.')');
if ($device['CLASS_THERMOSTAT'] && $rec['TITLE']=='ThermostatFanMode') {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[68].Set('.$value.')');
if ($device['CLASS_THERMOSTAT'] && preg_match('/ThermostatSetPoint (.+)/is', $rec['TITLE'], $m)) {
$mode_name=$m[1];
$mode='';
$av_modes=$data->commandClasses->{"67"}->data;
if ($av_modes->{"$i"}->modename->value==$mode_name) {
$mode=$i;
break;
if ($mode) {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$device['NODE_ID'].'].instances['.$device['INSTANCE_ID'].'].commandClasses[67].Set('.$mode.', '.$value.')');
$this->pollDevice($rec['DEVICE_ID']);
* Title
* Description
* @access public
function resetChip() {
http://IP-OF-RAZBERRY:8083/ZWaveAPI/Run ... ftReset(1)
$cmd="/ZWaveAPI/Run/SerialAPISoftReset(1)";
$data=$this->apiCall($cmd);
* Title
* Description
* @access public
function pollUpdates() {
if (!$this->latestPoll) {
$latest=$this->scanNetwork();
if (!$latest) {
echo "Error getting data!\n";
$this->latestPoll=$latest;
$unknown_device_found=0;
//sending update request for some properties
$properties=SQLSelect("SELECT zwave_properties.*,zwave_devices.NODE_ID, zwave_devices.INSTANCE_ID FROM zwave_properties LEFT JOIN zwave_devices ON zwave_properties.DEVICE_ID=zwave_devices.ID WHERE UPDATE_PERIOD>0 AND (IsNull(zwave_properties.NEXT_UPDATE) OR zwave_properties.NEXT_UPDATE<='".date('Y-m-d H:i:s')."')");
$total=count($properties);
$get_codes_added=array();
$properties[$i]['NEXT_UPDATE']=date('Y-m-d H:i:s', time()+$properties[$i]['UPDATE_PERIOD']);
if ($properties[$i]['COMMAND_CLASS'] && !$get_codes_added[$properties[$i]['NODE_ID'].'/'.$properties[$i]['INSTANCE_ID']]) {
$get_codes_added[$properties[$i]['NODE_ID'].'/'.$properties[$i]['INSTANCE_ID']]=1;
$cmd='/ZWaveAPI/Run/devices['.$properties[$i]['NODE_ID'].'].instances['.$properties[$i]['INSTANCE_ID'].'].commandClasses['.$properties[$i]['COMMAND_CLASS'].'].Get()';
echo "Command: ".$cmd."\n";
unset($properties[$i]['NODE_ID']);
unset($properties[$i]['INSTANCE_ID']);
SQLUpdate('zwave_properties', $properties[$i]);
//polling network for updates
$data=$this->apiCall('/ZWaveAPI/Data/'.$this->latestPoll);
$latest=$data->updateTime;
if (!$latest) {
echo "Error getting updates!\n";
$this->latestDataReceived=time();
$data=(array)$data;
foreach($data as $k=>$v) {
if (preg_match('/devices\.(\d+)\.instances\.(\d+)\.commandClasses/', $k, $m)) {
$device_id=$m[1];
$instance_id=$m[2];
if (!$seen['d'.$device_id.'i'.$instance_id]) {
$seen['d'.$device_id.'i'.$instance_id]=1;
$rec=SQLSelectOne("SELECT ID from zwave_devices WHERE NODE_ID='".$device_id."' AND INSTANCE_ID='".$instance_id."'");
if (!$rec['ID']) {
echo "Unknown device (".$m[0].")\n";
$unknown_device_found=1;
echo "Polling device (".$m[0].") ...";
$this->pollDevice($rec['ID']);
echo "OK\n";
if ($rec['DEVICE_TYPE']==17) {
$remotes=SQLSelect("SELECT ID FROM zwave_devices WHERE DEVICE_TYPE=18");
foreach($remotes as $k=>$v) {
$this->pollDevice($v['ID']);
//print_r($data);
if ($unknown_device_found) {
if ($this->config['ZWAVE_API_RESET'] && ((time()-$this->latestDataReceived)>(int)$this->config['ZWAVE_API_RESET']) && ((time()-$this->latestReset))>15*60) {
// reset chip if no data was received during timeout set and latest reset was 15 minutes ago or latesr
$this->latestReset=time();
$this->resetChip();
function propertySetHandle($object, $property, $value) {
$zwave_properties=SQLSelect("SELECT ID FROM zwave_properties WHERE LINKED_OBJECT LIKE '".DBSafe($object)."' AND LINKED_PROPERTY LIKE '".DBSafe($property)."'");
$total=count($zwave_properties);
if ($total) {
$this->setProperty($zwave_properties[$i]['ID'], $value);
* Title
* Description
* @access public
function pollDevice($device_id, $data=0) {
$rec=SQLSelectOne("SELECT * FROM zwave_devices WHERE ID='".$device_id."'");
$rec_updated=0;
$comments=array();
$updatedList=array();
$properties=array();
$command_classes=array();
if (!$data) {
$data=$this->apiCall('/ZWaveAPI/Run/devices['.$rec['NODE_ID'].'].instances['.$rec['INSTANCE_ID'].']');
if (!$data) {
return 0;
if ($_GET['debug']) {
//echo $data->updateTime;exit;
var_dump($data);
$updateTime=0;
if (!$rec['RAW_DATA']) {
$rec_updated=1;
$rec['RAW_DATA']=json_encode($data);
$rec['SENSOR_VALUE']='';
if ($data->data->updateTime) {
$updateTime=$data->data->updateTime;
if ($rec['CLASS_BASIC']) {
$value=$data->commandClasses->{"32"}->data->value;
if ($value!==$rec['BASIC']) {
$rec['BASIC']=$value;
$rec_updated=1;
$command_classes['Basic']=32;
$properties['Basic']=$rec['BASIC'];
$updatedList['Basic']=$data->commandClasses->{"32"}->data->{"updateTime"};
if ($data->commandClasses->{"32"}->data->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"32"}->data->{"updateTime"};
if ($rec['CLASS_SENSOR_BINARY']) {
$sensor_data=$data->commandClasses->{"48"}->data;
if (isset($data->commandClasses->{"48"}->data->{"1"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"1"};
if (isset($data->commandClasses->{"48"}->data->{"2"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"2"};
if (isset($data->commandClasses->{"48"}->data->{"3"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"3"};
if (isset($data->commandClasses->{"48"}->data->{"4"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"4"};
if (isset($data->commandClasses->{"48"}->data->{"5"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"5"};
if (isset($data->commandClasses->{"48"}->data->{"6"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"6"};
if (isset($data->commandClasses->{"48"}->data->{"7"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"7"};
if (isset($data->commandClasses->{"48"}->data->{"8"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"8"};
if (isset($data->commandClasses->{"48"}->data->{"9"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"9"};
if (isset($data->commandClasses->{"48"}->data->{"10"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"10"};
if (isset($data->commandClasses->{"48"}->data->{"11"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"11"};
if (isset($data->commandClasses->{"48"}->data->{"12"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"12"};
if (isset($data->commandClasses->{"48"}->data->{"13"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"13"};
if (isset($data->commandClasses->{"48"}->data->{"14"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"14"};
if (isset($data->commandClasses->{"48"}->data->{"15"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"15"};
if (isset($data->commandClasses->{"48"}->data->{"16"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"16"};
if (isset($data->commandClasses->{"48"}->data->{"17"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"17"};
if (isset($data->commandClasses->{"48"}->data->{"18"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"18"};
if (isset($data->commandClasses->{"48"}->data->{"19"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"19"};
if (isset($data->commandClasses->{"48"}->data->{"20"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"20"};
if (isset($data->commandClasses->{"48"}->data->{"21"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"21"};
if (isset($data->commandClasses->{"48"}->data->{"22"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"22"};
if (isset($data->commandClasses->{"48"}->data->{"23"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"23"};
if (isset($data->commandClasses->{"48"}->data->{"24"})) {
$sensor_data=$data->commandClasses->{"48"}->data->{"24"};
$value=(int)$sensor_data->level->value;
if ($value!==$rec['LEVEL']) {
$rec['LEVEL']=$value;
$rec_updated=1;
$properties['Level']=$rec['LEVEL'];
$command_classes['Level']=48;
$updatedList['Level']=$sensor_data->{"updateTime"};
if ($sensor_data->{"updateTime"}>$updateTime) {
$updateTime=$sensor_data->{"updateTime"};
//if ($rec['CLASS_SENSOR_NOTIFICATION']) {
//$sensor_data=$data->commandClasses->{"113"}->data;
// if (isset($data->commandClasses->{"113"}->data->{"5"})) {
// $sensor_data=$data->commandClasses->{"113"}->data->{"5"};
// if (isset($data->commandClasses->{"113"}->data->{"6"})) {
// $sensor_data=$data->commandClasses->{"113"}->data->{"6"};
// if (isset($data->commandClasses->{"113"}->data->{"7"})) {
// $sensor_data=$data->commandClasses->{"113"}->data->{"7"};
//$value=(int)$sensor_data->event->value;
//if ($value!==$rec['EVENT']) {
//$rec['EVENT']=$value;
//$rec_updated=1;
//$properties['EVENT']=$rec['EVENT'];
//$command_classes['EVENT']=113;
//$updatedList['EVENT']=$sensor_data->{"updateTime"};
//if ($sensor_data->{"updateTime"}>$updateTime) {
//$updateTime=$sensor_data->{"updateTime"};
// multiple sensor support required!
//SENSOR_VALUE
$values=array();
if (isset($data->commandClasses->{"113"}->data->{"$i"})) {
$sensor=$data->commandClasses->{"113"}->data->{"$i"};
$values[]=trim($sensor->sensorTypeString->value).': '.$sensor->event->value.$sensor->scaleString->value;
if (trim($sensor->sensorTypeString->value)) {
$prop_name=trim($sensor->sensorTypeString->value).', '.$sensor->scaleString->value;
$prop_name="Sensor $i";
if ($properties[$prop_name]) {
$prop_name.=' (1)';
$properties[$prop_name]=$sensor->event->value;
$command_classes[$prop_name]=113;
$updatedList[$prop_name]=$data->commandClasses->{"113"}->data->{"$i"}->{"updateTime"};
if ($data->commandClasses->{"113"}->data->{"$i"}->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"113"}->data->{"$i"}->{"updateTime"};
$value=implode('; ', $values);
if ($value!=$rec['SENSOR_VALUE']) {
$rec['SENSOR_VALUE'].=$value.';';
$rec_updated=1;
if ($rec['CLASS_SENSOR_MULTILEVEL']) {
//SENSOR_VALUE
$values=array();
if (isset($data->commandClasses->{"49"}->data->{"$i"})) {
$sensor=$data->commandClasses->{"49"}->data->{"$i"};
$values[]=trim($sensor->sensorTypeString->value).': '.$sensor->val->value.$sensor->scaleString->value;
$prop_name.=' (1)';
$properties[$prop_name]=$sensor->val->value;
$command_classes[$prop_name]=49;
$updatedList[$prop_name]=$data->commandClasses->{"49"}->data->{"$i"}->{"updateTime"};
if ($data->commandClasses->{"49"}->data->{"$i"}->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"49"}->data->{"$i"}->{"updateTime"};
$rec_updated=1;
if ($rec['CLASS_SWITCH_BINARY']) {
$value=(int)$data->commandClasses->{"37"}->data->level->value;
$rec_updated=1;
$command_classes['Level']=37;
$updatedList['Level']=$data->commandClasses->{"37"}->data->{"updateTime"};
if ($data->commandClasses->{"37"}->data->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"37"}->data->{"updateTime"};
if ($rec['CLASS_SWITCH_MULTILEVEL']) {
$value=(int)$data->commandClasses->{"38"}->data->level->value;
$rec_updated=1;
$command_classes['Level']=38;
$updatedList['Level']=$data->commandClasses->{"38"}->data->{"updateTime"};
if ($data->commandClasses->{"38"}->data->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"38"}->data->{"updateTime"};
$properties['LevelDuration command (level, duration)']='';
if ($rec['CLASS_BATTERY']) {
$value=(int)$data->commandClasses->{"128"}->data->last->value;
if ($value!=$rec['BATTERY_LEVEL']) {
$rec['BATTERY_LEVEL']=$value;
$rec_updated=1;
$command_classes['Battery']=128;
$properties['Battery']=$rec['BATTERY_LEVEL'];
$updatedList['Battery']=$data->commandClasses->{"128"}->data->{"updateTime"};
if ($data->commandClasses->{"128"}->data->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"128"}->data->{"updateTime"};
if ($rec['CLASS_METER']) {
// ... 50
$values=array();
if (isset($data->commandClasses->{"50"}->data->{"$i"})) {
$sensor=$data->commandClasses->{"50"}->data->{"$i"};
$values[]=trim($sensor->sensorTypeString->value).': '.$sensor->val->value.' '.$sensor->scaleString->value;
$prop_name="Meter $i";
$prop_name.=' (1)';
$command_classes[$prop_name]=50;
$updatedList[$prop_name]=$data->commandClasses->{"50"}->data->{"$i"}->{"updateTime"};
if ($data->commandClasses->{"50"}->data->{"$i"}->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"50"}->data->{"$i"}->{"updateTime"};
if ($value!='') {
$rec['SENSOR_VALUE'].=$value.'; ';
$rec_updated=1;
if ($rec['CLASS_SENSOR_ALARM']) {
// ... $data->commandClasses->{"156"}->data
if (is_object($data->commandClasses->{"156"}->data->{"0"}->sensorState)) {
$command_classes['AlarmGeneral']=156;
$properties['AlarmGeneral']=$data->commandClasses->{"156"}->data->{"0"}->sensorState->value;
$updatedList['AlarmGeneral']=$data->commandClasses->{"156"}->data->{"0"}->sensorState->updateTime;
$value=$properties['AlarmGeneral'];
if ($value!=$rec['LEVEL']) {
$rec_updated=1;
if (is_object($data->commandClasses->{"156"}->data->{"1"}->sensorState)) {
$command_classes['AlarmSmoke']=156;
$properties['AlarmSmoke']=$data->commandClasses->{"156"}->data->{"1"}->sensorState->value;
$updatedList['AlarmSmoke']=$data->commandClasses->{"156"}->data->{"1"}->sensorState->updateTime;
if (is_object($data->commandClasses->{"156"}->data->{"2"}->sensorState)) {
$command_classes['AlarmCarbonMonoxide']=156;
$properties['AlarmCarbonMonoxide']=$data->commandClasses->{"156"}->data->{"2"}->sensorState->value;
$updatedList['AlarmCarbonMonoxide']=$data->commandClasses->{"156"}->data->{"2"}->sensorState->updateTime;
if (is_object($data->commandClasses->{"156"}->data->{"3"}->sensorState)) {
$command_classes['AlarmCarbonDioxide']=156;
$properties['AlarmCarbonDioxide']=$data->commandClasses->{"156"}->data->{"3"}->sensorState->value;
$updatedList['AlarmCarbonDioxide']=$data->commandClasses->{"156"}->data->{"3"}->sensorState->updateTime;
if (is_object($data->commandClasses->{"156"}->data->{"4"}->sensorState)) {
$command_classes['AlarmHeat']=156;
$properties['AlarmHeat']=$data->commandClasses->{"156"}->data->{"4"}->sensorState->value;
$updatedList['AlarmHeat']=$data->commandClasses->{"156"}->data->{"4"}->sensorState->updateTime;
if (is_object($data->commandClasses->{"156"}->data->{"5"}->sensorState)) {
$command_classes['AlarmFlood']=156;
$properties['AlarmFlood']=$data->commandClasses->{"156"}->data->{"5"}->sensorState->value;
$updatedList['AlarmFlood']=$data->commandClasses->{"156"}->data->{"5"}->sensorState->updateTime;
if ($data->commandClasses->{"156"}->data->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"156"}->data->{"updateTime"};
if ($rec['CLASS_SCENE_CONTROLLER'] && is_object($data->commandClasses->{"43"}->data->{"currentScene"})) {
// ... 43
$properties['CurrentScene']=$data->commandClasses->{"43"}->data->{"currentScene"}->value;
$properties['TimeScene']=$data->commandClasses->{"43"}->data->{"currentScene"}->updateTime;
if ($data->commandClasses->{"43"}->data->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"43"}->data->{"updateTime"};
} elseif ($rec['CLASS_SCENE_CONTROLLER'] && is_object($data->commandClasses->{"45"}->data->{"currentScene"})) {
// ... 45
$properties['CurrentScene']=$data->commandClasses->{"45"}->data->{"currentScene"}->value;
if ($data->commandClasses->{"45"}->data->{"updateTime"}>$updateTime) {
if ($rec['CLASS_THERMOSTAT'] && isset($data->commandClasses->{"64"}->data->mode->value)) {
//$value=$data->commandClasses->{"64"}->data->{$data->commandClasses->{"64"}->data->mode->value}->modeName->value;
$rec['SENSOR_VALUE'].=" Mode: ".$data->commandClasses->{"64"}->data->{$data->commandClasses->{"64"}->data->mode->value}->modeName->value.';';
$value=$data->commandClasses->{"64"}->data->mode->value;
if ($value!=$rec['MODE_VALUE']) {
$rec['MODE_VALUE']=$value;
$rec_updated=1;
$command_classes['Thermostat mode']=64;
$properties['Thermostat mode']=$rec['MODE_VALUE'];
$updatedList['Thermostat mode']=$data->commandClasses->{"64"}->data->{"updateTime"};
if ($data->commandClasses->{"64"}->data->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"64"}->data->{"updateTime"};
$comments_str='';
if ($data->commandClasses->{"64"}->data->{$i}) {
$comments_str.="$i = ".$data->commandClasses->{"64"}->data->{$i}->modeName->value."; ";
$comments['Thermostat mode']=$comments_str;
if (isset($data->commandClasses->{"67"}->data)) {
//ThermostatSetPoint
if ($data->commandClasses->{"67"}->data->{$i}->val) {
$key='ThermostatSetPoint '.$data->commandClasses->{"67"}->data->{$i}->modeName->value;
$properties[$key]=$data->commandClasses->{"67"}->data->{$i}->val->value;
$command_classes[$key]=67;
if ($data->commandClasses->{"67"}->data->{$i}->scaleString->value) {
$comments[$key]=$data->commandClasses->{"67"}->data->{$i}->scaleString->value;
if (isset($data->commandClasses->{"68"}->data->mode->value)) {
//ThermostatFanMode
$properties['ThermostatFanOn']=(int)$data->commandClasses->{"68"}->data->on->value;
$command_classes['ThermostatFanMode']=68;
$properties['ThermostatFanMode']=$data->commandClasses->{"68"}->data->mode->value;
if ($data->commandClasses->{"68"}->data->{"updateTime"}>$updateTime) {
$updateTime=$data->commandClasses->{"68"}->data->{"updateTime"};
$rec['SENSOR_VALUE'].=" Fan Mode: ".$data->commandClasses->{"68"}->data->{$data->commandClasses->{"68"}->data->mode->value}->modeName->value.';';
$comments_str='';
if ($data->commandClasses->{"68"}->data->{$i}) {
$comments_str.="$i = ".$data->commandClasses->{"68"}->data->{$i}->modeName->value."; ";
$comments['ThermostatFanMode']=$comments_str;
if ($updateTime) {
$properties['updateTime']=$updateTime;
$rec['LATEST_UPDATE']=date('Y-m-d H:i:s', $properties['updateTime']);
$rec_updated=1;
if ($rec_updated) {
foreach($properties as $k=>$v) {
$prop=SQLSelectOne("SELECT * FROM zwave_properties WHERE DEVICE_ID='".$rec['ID']."' AND UNIQ_ID LIKE '".DBSafe($k)."'");
$prop['DEVICE_ID']=$rec['ID'];
$prop['UNIQ_ID']=$k;
$prop['TITLE']=$k;
$prop['COMMAND_CLASS']=$command_classes[$k];
if ($prop['VALUE']!=$v) {
$prop['UPDATED']=date('Y-m-d H:i:s');
if ($updatedList[$k]) {
$prop['UPDATED']=date('Y-m-d H:i:s', $updatedList[$k]);
$old_value=$prop['VALUE']; // save value to overwrite
$prop['VALUE']=$v;
if ($comments[$k]) {
$prop['COMMENTS']=$comments[$k];
if (is_numeric($prop['VALUE']) && $prop['VALUE']!=='') {
$prop['VALUE']=round($prop['VALUE'], 3);
if ($prop['ID']) {
SQLUpdate('zwave_properties', $prop);
if ($prop['VALUE']!=='') {
$validated=1;
$validated=0;
continue;
if ($prop['LINKED_OBJECT']) {
if ($prop['CORRECT_VALUE']) {
$prop['VALUE']+=(float)$prop['CORRECT_VALUE'];
if ($prop['VALIDATE']) {
if (((float)$prop['VALUE']<(float)$prop['VALID_FROM']) || ((float)$prop['VALUE']>(float)$prop['VALID_TO'])) {
$validated=0;
if ($prop['LINKED_OBJECT'] && $prop['LINKED_PROPERTY'] && $validated) {
//$old_value=getGlobal($prop['LINKED_OBJECT'].'.'.$prop['LINKED_PROPERTY']);
if ($prop['VALUE']!=$old_value) {
setGlobal($prop['LINKED_OBJECT'].'.'.$prop['LINKED_PROPERTY'], $prop['VALUE'], array($this->name=>'0'));
if ($prop['LINKED_OBJECT'] && $prop['LINKED_METHOD'] && $validated && $prop['VALUE']!=$old_value) {
$params=array();
$params['VALUE']=$prop['VALUE'];
callMethod($prop['LINKED_OBJECT'].'.'.$prop['LINKED_METHOD'], $params);
$prop['ID']=SQLInsert('zwave_properties', $prop);
//print_r($data);exit;
* Title
* Description
* @access public
function apiCall($command) {
$this->getConfig();
$command=preg_replace('/^\//', '', $command);
$url=$this->config['ZWAVE_API_URL'].$command;
$cookie_file=ROOT.'cached/zwave_cookie.txt';
$ch = curl_init();
curl_setopt($ch, CURLOPT_HTTPHEADER, array('Accept: application/json, text/javascript', 'Content-Type: application/json'));
curl_setopt($ch, CURLOPT_COOKIEFILE, $cookie_file);
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, 30);
curl_setopt($ch, CURLOPT_TIMEOUT, 30);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, FALSE);
$result = curl_exec($ch);
curl_close($ch);
if (preg_match('/307 Temporary Redirect/is', $result)) {
if ($this->connect()) {
$ch = curl_init();
curl_close($ch);
return false;
SaveFile(ROOT.'cached/zwave_api.txt',$url."\n\n".$result);
return json_decode($result);
* FrontEnd
* Module frontend
* @access public
function usual(&$out) {
$this->admin($out);
* zwave_devices search
* @access public
function search_zwave_devices(&$out) {
require(DIR_MODULES.$this->name.'/zwave_devices_search.inc.php');
* zwave_devices edit/add
* @access public
function edit_zwave_devices(&$out, $id) {
require(DIR_MODULES.$this->name.'/zwave_devices_edit.inc.php');
* zwave_devices delete record
* @access public
function delete_zwave_devices($id) {
$rec=SQLSelectOne("SELECT * FROM zwave_devices WHERE ID='$id'");
// some action for related tables
SQLExec("DELETE FROM zwave_properties WHERE DEVICE_ID='".$rec['ID']."'");
SQLExec("DELETE FROM zwave_devices WHERE ID='".$rec['ID']."'");
* zwave_properties search
* @access public
function search_zwave_properties(&$out) {
require(DIR_MODULES.$this->name.'/zwave_properties_search.inc.php');
function prettyPrint($json)
$result = '';
$level = 0;
$in_quotes = false;
$in_escape = false;
$ends_line_level = NULL;
$json_length = strlen( $json );
for( $i = 0; $i < $json_length; $i++ ) {
$char = $json[$i];
$new_line_level = NULL;
$post = "";
if( $ends_line_level !== NULL ) {
$new_line_level = $ends_line_level;
if ( $in_escape ) {
$in_escape = false;
} else if( $char === '"' ) {
$in_quotes = !$in_quotes;
} else if( ! $in_quotes ) {
switch( $char ) {
case '}': case ']':
$level--;
$new_line_level = $level;
break;
case '{': case '[':
$level++;
case ',':
$ends_line_level = $level;
break;
case ':':
$post = " ";
break;
case " ": case "\t": case "\n": case "\r":
$char = "";
$ends_line_level = $new_line_level;
break;
} else if ( $char === '\\' ) {
$in_escape = true;
if( $new_line_level !== NULL ) {
$result .= "\n".str_repeat( "\t", $new_line_level );
$result .= $char.$post;
return $result;
* Install
* Module installation routine
* @access private
function install($data='') {
parent::install();
* Uninstall
* Module uninstall routine
* @access public
function uninstall() {
SQLExec('DROP TABLE IF EXISTS zwave_devices');
SQLExec('DROP TABLE IF EXISTS zwave_properties');
parent::uninstall();
* dbInstall
* Database installation routine
* @access private
function dbInstall($data) {
zwave_devices - Z-Wave
zwave_properties - Properties
$data = <<<EOD
zwave_devices: ID int(10) unsigned NOT NULL auto_increment
zwave_devices: TITLE varchar(255) NOT NULL DEFAULT ''
zwave_devices: NODE_ID varchar(50) NOT NULL DEFAULT ''
zwave_devices: INSTANCE_ID varchar(50) NOT NULL DEFAULT ''
zwave_devices: BASIC varchar(50) NOT NULL DEFAULT ''
zwave_devices: LEVEL varchar(50) NOT NULL DEFAULT ''
zwave_devices: EVENT varchar(50) NOT NULL DEFAULT ''
zwave_devices: BATTERY_LEVEL varchar(50) NOT NULL DEFAULT ''
zwave_devices: SENSOR_VALUE varchar(255) NOT NULL DEFAULT ''
zwave_devices: MODE_VALUE varchar(255) NOT NULL DEFAULT ''
zwave_devices: DEVICE_TYPE varchar(50) NOT NULL DEFAULT ''
zwave_devices: STATUS int(3) NOT NULL DEFAULT '0'
zwave_devices: AUTO_POLL int(3) NOT NULL DEFAULT '0'
zwave_devices: LATEST_UPDATE datetime
zwave_devices: LOCATION_ID int(10) NOT NULL DEFAULT '0'
zwave_devices: CLASS_BASIC int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_SENSOR_BINARY int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_SENSOR_NOTIFICATION int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_SENSOR_MULTILEVEL int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_SWITCH_BINARY int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_SWITCH_MULTILEVEL int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_METER int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_BATTERY int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_THERMOSTAT int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_SENSOR_ALARM int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_SCENE_CONTROLLER int(3) NOT NULL DEFAULT '0'
zwave_devices: CLASS_CONFIG int(3) NOT NULL DEFAULT '0'
zwave_devices: ALL_CLASSES varchar(255) NOT NULL DEFAULT ''
zwave_devices: BRAND varchar(255) NOT NULL DEFAULT ''
zwave_devices: PRODUCT varchar(255) NOT NULL DEFAULT ''
zwave_devices: XMLFILE varchar(255) NOT NULL DEFAULT ''
zwave_devices: RAW_DATA text
zwave_properties: ID int(10) unsigned NOT NULL auto_increment
zwave_properties: DEVICE_ID int(10) NOT NULL DEFAULT '0'
zwave_properties: UNIQ_ID varchar(100) NOT NULL DEFAULT ''
zwave_properties: TITLE varchar(255) NOT NULL DEFAULT ''
zwave_properties: COMMENTS varchar(255) NOT NULL DEFAULT ''
zwave_properties: VALUE varchar(255) NOT NULL DEFAULT ''
zwave_properties: VALUE_TYPE varchar(255) NOT NULL DEFAULT ''
zwave_properties: READ_ONLY int(3) NOT NULL DEFAULT '0'
zwave_properties: UPDATE_PERIOD int(10) NOT NULL DEFAULT '0'
zwave_properties: VALIDATE int(3) NOT NULL DEFAULT '0'
zwave_properties: VALID_FROM varchar(10) NOT NULL DEFAULT ''
zwave_properties: VALID_TO varchar(10) NOT NULL DEFAULT ''
zwave_properties: CORRECT_VALUE varchar(10) NOT NULL DEFAULT ''
zwave_properties: COMMAND_CLASS varchar(10) NOT NULL DEFAULT ''
zwave_properties: LINKED_OBJECT varchar(255) NOT NULL DEFAULT ''
zwave_properties: LINKED_PROPERTY varchar(255) NOT NULL DEFAULT ''
zwave_properties: LINKED_METHOD varchar(255) NOT NULL DEFAULT ''
zwave_properties: UPDATED datetime
zwave_properties: NEXT_UPDATE datetime
EOD;
parent::dbInstall($data);
* TW9kdWxlIGNyZWF0ZWQgTWF5IDMwLCAyMDEzIHVzaW5nIFNlcmdlIEouIHdpemFyZCAoQWN0aXZlVW5pdCBJbmMgd3d3LmFjdGl2ZXVuaXQuY29tKQ==
