Устанавливал без скриптов. Покомандно, поскольку в линуксе крайне слаб, хотелось понимать хоть как-то, что происходит.
Встало, вроде без проблем. Однако, при старте системы MD не стартует.
Статус выдает такойSPOILER_SHOW
orangepi@orangepipc2:~$ sudo service majordomo status
? majordomo.service - MajorDoMo
Loaded: loaded (/etc/systemd/system/majordomo.service; enabled; vendor preset: enabled)
Active: failed (Result: start-limit-hit) since Mon 2019-01-07 18:28:34 MSK; 4min 35s ago
Process: 1264 ExecStart=/usr/bin/php /var/www/cycle.php (code=exited, status=0/SUCCESS)
Main PID: 1264 (code=exited, status=0/SUCCESS)
янв 07 18:28:34 orangepipc2 systemd[1]: majordomo.service: Service hold-off time over, scheduling restart.
янв 07 18:28:34 orangepipc2 systemd[1]: majordomo.service: Scheduled restart job, restart counter is at 5.
янв 07 18:28:34 orangepipc2 systemd[1]: Stopped MajorDoMo.
янв 07 18:28:34 orangepipc2 systemd[1]: majordomo.service: Start request repeated too quickly.
янв 07 18:28:34 orangepipc2 systemd[1]: majordomo.service: Failed with result 'start-limit-hit'.
янв 07 18:28:34 orangepipc2 systemd[1]: Failed to start MajorDoMo.
Active: failed (Result: start-limit-hit) since Mon 2019-01-07 18:28:34 MSK; 5min ago
18:34:51 Closing thread: exec php -q ./scripts/cycle_skype.php --params "a:0:{}" > /dev/null 2>&1
18:34:51 Closing thread: exec php -q ./scripts/cycle_dev_blynk.php --params "a:0:{}" > /dev/null 2>&1
18:34:51 Closing thread: exec php -q ./scripts/cycle_connect.php --params "a:0:{}" > /dev/null 2>&1
18:34:51 Closing thread: DISPLAY=:101 php ./scripts/cycle_X101_skype.php --params "a:0:{}"
18:34:51 Closing thread: exec php -q ./scripts/cycle_mqtt.php --params "a:0:{}" > /dev/null 2>&1
Полный текст статусаSPOILER_SHOW
Active: active (running) since Mon 2019-01-07 18:34:40 MSK; 1min 16s ago
Main PID: 1709 (php)
Tasks: 11 (limit: 1029)
CGroup: /system.slice/majordomo.service
+-1709 /usr/bin/php /var/www/cycle.php
+-1720 php -q ./scripts/cycle_phistory.php --params a:0:{}
+-1721 php -q ./scripts/cycle_websockets.php --params a:0:{}
+-1722 php -q ./scripts/cycle_states.php --params a:0:{}
+-1723 php -q ./scripts/cycle_webvars.php --params a:0:{}
+-1726 php -q ./scripts/cycle_execs.php --params a:0:{}
+-1728 php -q ./scripts/cycle_main.php --params a:0:{}
+-1729 php -q ./scripts/cycle_dev_broadlink.php --params a:0:{}
+-1732 php -q ./scripts/cycle_wscache.php --params a:0:{}
+-1733 php -q ./scripts/cycle_scheduler.php --params a:0:{}
L-1734 php -q ./scripts/cycle_ping.php --params a:0:{}
янв 07 18:34:50 orangepipc2 php[1709]: OK
янв 07 18:34:50 orangepipc2 php[1709]: Starting ./scripts/cycle_mqtt.php ...
янв 07 18:34:50 orangepipc2 php[1709]: 18:34:50 Starting thread: exec php -q ./scripts/cycle_mqtt.php --params "a:0:{}" > /dev/null 2>&1
янв 07 18:34:50 orangepipc2 php[1709]: ALL CYCLES STARTED
янв 07 18:34:51 orangepipc2 php[1709]: 18:34:51 Closing thread: exec php -q ./scripts/cycle_skype.php --params "a:0:{}" > /dev/null 2>&1
янв 07 18:34:51 orangepipc2 php[1709]: 18:34:51 Closing thread: exec php -q ./scripts/cycle_dev_blynk.php --params "a:0:{}" > /dev/null 2>&1
янв 07 18:34:51 orangepipc2 php[1709]: 18:34:51 Closing thread: exec php -q ./scripts/cycle_connect.php --params "a:0:{}" > /dev/null 2>&1
янв 07 18:34:51 orangepipc2 php[1709]: 18:34:51 Closing thread: DISPLAY=:101 php ./scripts/cycle_X101_skype.php --params "a:0:{}"
янв 07 18:34:51 orangepipc2 php[1709]: 18:34:51 Closing thread: exec php -q ./scripts/cycle_mqtt.php --params "a:0:{}" > /dev/null 2>&1
