Странные ошибки
Amarok
Странные ошибки
Сообщение Amarok »
С недавнего времени стала моя Алиска с запозданием выполнять некоторые действия из oneNewMinute, а точнее задачи повешенные на нулевую минуту часа (например может сообщить текущее время не в 0 минут, а спустя 2-3 минуты)
Открыл X-Ray и увидел кучу подобного:
14:10:45 0.33532100 GetURL to http://127.0.0.1:80/objects/?object=ClockChime&op=m&m=onNewMinute (source raiseEvent) finished with error:
Operation timed out after 45001 milliseconds with 0 bytes received
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.001292,"namelookup_time":6.4e-5,"connect_time":0.000261,"pretransfer_time":0.008187,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":0,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":59331}
13:30:45 0.38943600 GetURL to http://127.0.0.1:80/objects/?object=ClockChime&op=m&m=onNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.001867,"namelookup_time":8.2e-5,"connect_time":0.00028,"pretransfer_time":0.000463,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":0,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":57039}
12:50:45 0.79446500 GetURL to http://127.0.0.1:80/objects/?object=ClockChime&op=m&m=onNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.001296,"namelookup_time":7.6e-5,"connect_time":0.000277,"pretransfer_time":0.000438,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":0,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":54652}
12:30:45 0.67139400 GetURL to http://127.0.0.1:80/objects/?object=ClockChime&op=m&m=onNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.001486,"namelookup_time":6.1e-5,"connect_time":0.000265,"pretransfer_time":0.000421,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":0,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":53353}
11:40:45 0.91222600 GetURL to http://127.0.0.1:80/objects/?object=ClockChime&op=m&m=onNewMinute (source raiseEvent) finished with error:
{"url":"http:\/\/127.0.0.1:80\/objects\/?object=ClockChime&op=m&m=onNewMinute","content_type":null,"http_code":0,"header_size":0,"request_size":188,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":45.00183,"namelookup_time":6.1e-5,"connect_time":0.000266,"pretransfer_time":0.000419,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":0,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"127.0.0.1","certinfo":[],"primary_port":80,"local_ip":"127.0.0.1","local_port":50218}
Чо эт она?
igorewa
Re: Странные ошибки
Сообщение igorewa »
Я моя стала тупить при выполнения команды из шаблона поведения, говоришь Алиса выключи свет в коридоре, ответ в колонки выполнено, а свет выключается секунд через 40-80, или вообще не выключает
webms
Re: Странные ошибки
Сообщение webms »
и как решили проблему ?
Chainik
Re: Странные ошибки
Сообщение Chainik »
Может и не от этого, но помнится ув.Vovix писал, что желательно, запускать задачи из onNewMinute через SetTimeOut, чтобы все задачи запускались в отдельных самостоятельных процессах. А то многие "напихивают" туда кучу всего, что сам onNewMinute начитает сбоить в результате превышения таймаута.
webms
Re: Странные ошибки
Сообщение webms »
это понятно, я про ошибку
она не и за onNewMinute появляется
Re: Странные ошибки
webms писал(а): Вт дек 04, 2018 7:51 pm это понятно, я про ошибку
код весь из метода покажите и далее разбираться что там вызывается, как там запросы в интернет, какие проверки в скриптах и т.п.
