Здравствуйте.nick7zmail писал(а): 1. Вверху кнопка настроить - туда вписываете URL сервера (http://blynk-cloud.com для облачного сервиса, http://ваш_айпи:порт (порт по умолчанию 8080) - для локального)
При установке сервера возникла проблема с портом 8080, так как он уже занят VLC, вопрос:- как переназначить порт.
14:40:42.588 INFO - Region : local
14:40:44.423 INFO - Initializing gmail smtp mail transport. Username : [email protected]. SMTP host : smtp.gmail.com:587
14:40:45.156 INFO - Didn't find custom user certificates.
14:40:45.160 INFO - Didn't find Let's Encrypt certificates.
14:40:45.160 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
14:40:45.163 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
14:40:46.850 INFO - Hardware plain tcp/ip server listening at 8442 port.
14:40:46.854 INFO - Hardware SSL server listening at 8441 port.
14:40:46.855 INFO - Application server listening at 8443 port.
14:40:46.858 ERROR- Error initializing HTTP API and WebSockets, port 8080
java.net.BindException: Адрес уже используется
at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_65]
at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_65]
at sun.nio.ch.Net.bind(Net.java:425) ~[?:1.8.0_65]
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:1.8.0_65]
at io.netty.channel.socket.nio.NioServerSocketChannel.doBind(NioServerSocketChannel.java:128) ~[server-0.24.6.jar:?]
at io.netty.channel.AbstractChannel$AbstractUnsafe.bind(AbstractChannel.java:554) ~[server-0.24.6.jar:?]
at io.netty.channel.DefaultChannelPipeline$HeadContext.bind(DefaultChannelPipeline.java:1258) ~[server-0.24.6.jar:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeBind(AbstractChannelHandlerContext.java:501) ~[server-0.24.6.jar:?]
at io.netty.channel.AbstractChannelHandlerContext.bind(AbstractChannelHandlerContext.java:486) ~[server-0.24.6.jar:?]
at io.netty.channel.DefaultChannelPipeline.bind(DefaultChannelPipeline.java:980) ~[server-0.24.6.jar:?]
at io.netty.channel.AbstractChannel.bind(AbstractChannel.java:250) ~[server-0.24.6.jar:?]
at io.netty.bootstrap.AbstractBootstrap$2.run(AbstractBootstrap.java:365) ~[server-0.24.6.jar:?]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163) ~[server-0.24.6.jar:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:403) ~[server-0.24.6.jar:?]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:462) ~[server-0.24.6.jar:?]
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:858) ~[server-0.24.6.jar:?]
at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:138) ~[server-0.24.6.jar:?]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_65]
14:53:08.386 INFO - Using data dir '/home/pi/Blynk'
14:53:08.712 INFO - Region : local
14:53:10.328 INFO - Initializing gmail smtp mail transport. Username : [email protected]. SMTP host : smtp.gmail.com:587
14:53:11.056 INFO - Didn't find custom user certificates.
14:53:11.060 INFO - Didn't find Let's Encrypt certificates.
14:53:11.060 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
14:53:11.062 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
14:53:13.466 INFO - Hardware plain tcp/ip server listening at 8442 port.
14:53:13.470 INFO - Hardware SSL server listening at 8441 port.
14:53:13.472 INFO - Application server listening at 8443 port.
14:53:13.474 ERROR- Error initializing HTTP API and WebSockets, port 8080
15:05:34.476 INFO - Using data dir '/home/pi/Blynk'
15:05:34.907 INFO - Region : local
15:05:36.781 INFO - Initializing gmail smtp mail transport. Username : [email protected]. SMTP host : smtp.gmail.com:587
15:05:37.609 INFO - Didn't find custom user certificates.
15:05:37.615 INFO - Didn't find Let's Encrypt certificates.
15:05:37.615 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
15:05:37.618 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
15:05:39.554 INFO - Hardware plain tcp/ip server listening at 8442 port.
15:05:39.558 INFO - Hardware SSL server listening at 8441 port.
15:05:39.560 INFO - Application server listening at 8443 port.
15:05:39.564 ERROR- Error initializing HTTP API and WebSockets, port 8080
