Регулярно пропадает доступ через nginx (110: Connection timed out)
Stor
Сообщение Stor »
Всем привет.
Уже не первый раз замечаю, что через определенное время мажор становиться недоступным. Если перезагрузить nginx, то все ок.
При попытке достучаться до Мажора, получаем 504 Gateway Time-out.
/var/log/nginx/error.log:
2019/07/05 18:47:20 [error] 16667#16667: *131530 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.110, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock", host: "192.168.1.160"
2019/07/05 18:50:07 [error] 16669#16669: *131533 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.110, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock", host: "192.168.1.160"
2019/07/05 19:30:31 [error] 16670#16670: *131555 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.110, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock", host: "192.168.1.160"
2019/07/05 20:11:17 [error] 16669#16669: *131600 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.1.110, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock", host: "192.168.1.160"
При попытке достучаться локально тоже провал:
root@orangepiprime:~# telnet localhost 80
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
Connection closed by foreign host.
/etc/nginx/nginx.conf:
user                    www-data;
worker_processes        4;
worker_rlimit_nofile    8192;
error_log               /var/log/nginx/error.log error;
pid                     /var/run/nginx.pid;
events {
  worker_connections    1024;
http {
  include               /etc/nginx/mime.types;
  default_type  application/octet-stream;
  log_format    main    '$remote_addr - $remote_user [$time_local] "$request" '
                        '$status $body_bytes_sent "$http_referer" '
                        '"$http_user_agent" "$http_x_forwarded_for"';
  access_log    /var/log/nginx/access.log main;
  client_body_temp_path /var/spool/nginx_client_body_temp;
  sendfile      on;
  tcp_nopush    on;
  tcp_nodelay   on;
  server_tokens off;
  server_names_hash_bucket_size 128;
server {
    server_name     localhost md.lan;
    root            /var/www;
    listen           80;
    index           index.html index.htm index.php default.html;
    access_log      off;
    client_max_body_size 150M;
    # настройки тюнинга https://xakep.ru/2010/12/15/54168/
    # Максимальный размер буфера для хранения тела запроса клиента
    client_body_buffer_size 1K;
    # Максимальный размер буфера для хранения заголовков запроса клиента
    client_header_buffer_size 1k;
    # Максимальный размер тела запроса клиента, прописанный в поле Content-Length заголовка. Если сервер должен поддерживать загрузку файлов, это значение необходимо увеличить
    #client_max_body_size 1k;
    # Количество и размер буферов для чтения большого заголовка запроса клиента
    large_client_header_buffers 2 1k;
    # Таймаут при чтении тела запроса клиента
    client_body_timeout 10;
    # Таймаут при чтении заголовка запроса клиента
    client_header_timeout 10;
    # Таймаут, по истечению которого keep-alive соединение с клиентом не будет закрыто со стороны сервера
    keepalive_timeout 5 5;
    # Таймаут при передаче ответа клиенту
    send_timeout 10;
    # обрабатывать только запросы GET HEAD POST
    if ($request_method !~ ^(GET|HEAD|POST)$ ) {
    return 444;
    location / {
          rewrite pda$ /popup/pda.html redirect;
          rewrite ^api/ /api.php;
              if (!-e $request_filename){
              rewrite ^(.*)$ /nf.php;
         # настройки тюнинга
         # обращение только по DNS имени
         #if ($host !~ ^(md.lan|www.md.lan)$ ) {
         #return 444;
    location /config.php {
          deny all;
    location ~* "/\.(htaccess|htpasswd)$" {
          deny all;
          return 404;
    location ~ \.php$ {
          fastcgi_index index.php;
          fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
          fastcgi_split_path_info ^(.+\.php)(/.+)$;
          set $path_info $fastcgi_path_info;
          fastcgi_param PATH_INFO $path_info;
          fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
          fastcgi_param PATH_TRANSLATED $document_root$fastcgi_path_info;
          include /etc/nginx/fastcgi_params;
          fastcgi_param PHP_VALUE "short_open_tag=on";
          fastcgi_param PHP_VALUE "error_reporting=E_ALL & ~E_NOTICE";
          fastcgi_param PHP_VALUE "max_execution_time=90";
          fastcgi_param PHP_VALUE "max_input_time=180";
          fastcgi_param PHP_VALUE "post_max_size=200M";
          fastcgi_param PHP_VALUE "upload_max_filesize=50M";
          fastcgi_param PHP_VALUE "max_file_uploads=150";
          fastcgi_read_timeout 400;
   location /api {
		  rewrite ^(.*)$ /api.php;
Stor
Re: Регулярно пропадает доступ через nginx (110: Connection timed out)
Сообщение Stor »
Странно, сейчас после перезагрузки nginx, мажор недоступен все равно.
Ошибки nginx:
2019/07/05 20:26:49 [alert] 22221#22221: *1 open socket #12 left in connection 2
2019/07/05 20:26:49 [alert] 22221#22221: *2 open socket #13 left in connection 3
2019/07/05 20:26:49 [alert] 22221#22221: aborting
Проверяю статус nginx - вижу ошибки ExecStop:
root@orangepiprime:~# systemctl status nginx
* nginx.service - A high performance web server and a reverse proxy server
   Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2019-07-05 20:26:49 MSK; 47s ago
     Docs: man:nginx(8)
  Process: 22263 ExecStop=/sbin/start-stop-daemon --quiet --stop --retry QUIT/5 --pidfile /run/nginx.pid (code=exited, status=2)
  Process: 22269 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
  Process: 22266 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
 Main PID: 22270 (nginx)
    Tasks: 5 (limit: 4915)
   CGroup: /system.slice/nginx.service
           |-22270 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
           |-22271 nginx: worker process
           |-22272 nginx: worker process
           |-22273 nginx: worker process
           `-22274 nginx: worker process
Видимо ошибка было не в nginx, а в majordomo, так как после его перезагрузки, он стал доступен.
Причем странно, почему он сам не перезагрузился, так как я добавил в /etc/systemd/system/majordomo.service:
[Service]
Restart=on-failure
RestartSec=60s
Или может кто знает проверенный способ перезапускать Мажор если он завис?
