Сообщение
adzam » Сб мар 15, 2014 6:34 pm
или помогите мне пожалуйста, вот мой код:
{"id": 0, "Text": "Sensor", "Children":
[{"id": 1, "Text": "HOME-E78C34B9F1", "Children":
[{"id": 2, "Text": "MSI MS-7270", "Children":
[{"id": 3, "Text": "Winbond W83627EHF", "Children":
[{"id": 4, "Text": "Voltages", "Children":
[{"id": 5, "Text": "CPU VCore", "Children": [], "Min": "1,264 V", "Value": "1,280 V", "Max": "1,304 V", "ImageURL": "images/transparent.png"},
{"id": 6, "Text": "Voltage #2", "Children": [], "Min": "2,040 V", "Value": "2,040 V", "Max": "2,040 V", "ImageURL": "images/transparent.png"},
{"id": 7, "Text": "AVCC", "Children": [], "Min": "3,296 V", "Value": "3,296 V", "Max": "3,312 V", "ImageURL": "images/transparent.png"},
{"id": 8, "Text": "3VCC", "Children": [], "Min": "3,296 V", "Value": "3,296 V", "Max": "3,312 V", "ImageURL": "images/transparent.png"},
{"id": 9, "Text": "Voltage #5", "Children": [], "Min": "1,696 V", "Value": "1,696 V", "Max": "1,696 V", "ImageURL": "images/transparent.png"},
{"id": 10, "Text": "Voltage #6", "Children": [], "Min": "1,864 V", "Value": "1,872 V", "Max": "1,872 V", "ImageURL": "images/transparent.png"},
{"id": 11, "Text": "Voltage #7", "Children": [], "Min": "1,872 V", "Value": "1,872 V", "Max": "1,872 V", "ImageURL": "images/transparent.png"},
{"id": 12, "Text": "3VSB", "Children": [], "Min": "3,296 V", "Value": "3,312 V", "Max": "3,312 V", "ImageURL": "images/transparent.png"},
{"id": 13, "Text": "VBAT", "Children": [], "Min": "1,824 V", "Value": "1,824 V", "Max": "1,888 V", "ImageURL": "images/transparent.png"},
{"id": 14, "Text": "Voltage #10", "Children": [], "Min": "1,544 V", "Value": "1,552 V", "Max": "1,552 V", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/voltage.png"},
{"id": 15, "Text": "Temperatures", "Children":
[{"id": 16, "Text": "CPU", "Children": [], "Min": "39,0 ТАC", "Value": "39,5 ТАC", "Max": "39,5 ТАC", "ImageURL": "images/transparent.png"},
{"id": 17, "Text": "Auxiliary", "Children": [], "Min": "42,5 ТАC", "Value": "43,0 ТАC", "Max": "43,0 ТАC", "ImageURL": "images/transparent.png"},
{"id": 18, "Text": "System", "Children": [], "Min": "32,0 ТАC", "Value": "32,0 ТАC", "Max": "32,0 ТАC", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/temperature.png"},
{"id": 19, "Text": "Fans", "Children":
[{"id": 20, "Text": "CPU Fan #2", "Children": [], "Min": "2280 RPM", "Value": "2296 RPM", "Max": "2312 RPM", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/fan.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/chip.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/mainboard.png"},
{"id": 21, "Text": "AMD Athlon 64 Processor 3500+", "Children":
[{"id": 22, "Text": "Clocks", "Children":
[{"id": 23, "Text": "Bus Speed", "Children": [], "Min": "201 MHz", "Value": "201 MHz", "Max": "201 MHz", "ImageURL": "images/transparent.png"},
{"id": 24, "Text": "CPU Core", "Children": [], "Min": "2211 MHz", "Value": "2211 MHz", "Max": "2211 MHz", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/clock.png"},
{"id": 25, "Text": "Temperatures", "Children": [{"id": 26, "Text": "Core #1", "Children": [], "Min": "41,0 ТАC", "Value": "41,0 ТАC", "Max": "43,0 ТАC", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/temperature.png"},
{"id": 27, "Text": "Load", "Children":
[{"id": 28, "Text": "CPU Core", "Children": [], "Min": "100,0 %", "Value": "100,0 %", "Max": "100,0 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/cpu.png"},
{"id": 29, "Text": "Generic Memory", "Children":
[{"id": 30, "Text": "Load", "Children":
[{"id": 31, "Text": "Memory", "Children": [], "Min": "64,3 %", "Value": "64,3 %", "Max": "64,4 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"},
{"id": 32, "Text": "Data", "Children":
[{"id": 33, "Text": "Used Memory", "Children": [], "Min": "1,6 GB", "Value": "1,6 GB", "Max": "1,6 GB", "ImageURL": "images/transparent.png"},
{"id": 34, "Text": "Available Memory", "Children": [], "Min": "0,9 GB", "Value": "0,9 GB", "Max": "0,9 GB", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/power.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/ram.png"},
{"id": 35, "Text": "NVIDIA GeForce 6500", "Children":
[{"id": 36, "Text": "Clocks", "Children":
[{"id": 37, "Text": "GPU Core", "Children": [], "Min": "398 MHz", "Value": "398 MHz", "Max": "398 MHz", "ImageURL": "images/transparent.png"},
{"id": 38, "Text": "GPU Memory", "Children": [], "Min": "266 MHz", "Value": "266 MHz", "Max": "266 MHz", "ImageURL": "images/transparent.png"},
{"id": 39, "Text": "GPU Shader", "Children": [], "Min": "0 MHz", "Value": "0 MHz", "Max": "0 MHz", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/clock.png"},
{"id": 40, "Text": "Temperatures", "Children":
[{"id": 41, "Text": "GPU Core", "Children": [], "Min": "44,0 ТАC", "Value": "44,0 ТАC", "Max": "44,0 ТАC", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/temperature.png"},
{"id": 42, "Text": "Load", "Children":
[{"id": 43, "Text": "GPU Core", "Children": [], "Min": "0,0 %", "Value": "0,0 %", "Max": "0,0 %", "ImageURL": "images/transparent.png"},
{"id": 44, "Text": "GPU Memory Controller", "Children": [], "Min": "0,0 %", "Value": "0,0 %", "Max": "0,0 %", "ImageURL": "images/transparent.png"},
{"id": 45, "Text": "GPU Video Engine", "Children": [], "Min": "0,0 %", "Value": "0,0 %", "Max": "0,0 %", "ImageURL": "images/transparent.png"},
{"id": 46, "Text": "GPU Memory", "Children": [], "Min": "12,2 %", "Value": "12,2 %", "Max": "12,2 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/nvidia.png"},
{"id": 47, "Text": "HDS728080PLA380", "Children":
[{"id": 48, "Text": "Temperatures", "Children":
[{"id": 49, "Text": "Temperature", "Children": [], "Min": "38,0 ТАC", "Value": "38,0 ТАC", "Max": "38,0 ТАC", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/temperature.png"},
{"id": 50, "Text": "Load", "Children":
[{"id": 51, "Text": "Used Space", "Children": [], "Min": "33,6 %", "Value": "33,6 %", "Max": "33,6 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/hdd.png"},
{"id": 52, "Text": "HDS728080PLA380", "Children":
[{"id": 53, "Text": "Temperatures", "Children":
[{"id": 54, "Text": "Temperature", "Children": [], "Min": "38,0 ТАC", "Value": "38,0 ТАC", "Max": "38,0 ТАC", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/temperature.png"},
{"id": 55, "Text": "Load", "Children":
[{"id": 56, "Text": "Used Space", "Children": [], "Min": "19,3 %", "Value": "19,3 %", "Max": "19,3 %", "ImageURL": "images/transparent.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/load.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/hdd.png"}], "Min": "", "Value": "", "Max": "", "ImageURL": "images_icon/computer.png"}], "Min": "Min", "Value": "Value", "Max": "Max", "ImageURL": ""}
