Help mysql Error
Добавлено: Сб фев 01, 2020 6:20 pm
В меню управления Пытался добавить новый раздел
Error
Details
Backtrace
Error
Details
http://192.168.10.13/admin.php?pd=cGFuZWw6e2FjdGlvbj1jb21tYW5kc30%3Dpz_&md=commands&inst=adm&
1366: Incorrect integer value: '' for column 'PRIORITY' at row 1
INSERT INTO `commands`(`PARENT_ID`, `TITLE`, `PRIORITY`, `SMART_REPEAT`, `READ_ONLY`, `TYPE`, `EXT_ID`, `INLINE`, `VISIBLE_DELAY`, `ICON`, `DATA`, `LINKED_OBJECT`, `LINKED_PROPERTY`, `ONCHANGE_METHOD`, `SCRIPT_ID`, `CODE`, `COMMAND`, `WINDOW`, `SUB_PRELOAD`, `URL`, `WIDTH`, `HEIGHT`, `AUTOSTART`, `AUTO_UPDATE`) VALUES('1', 'Онлайн радио', '', '0', '0', 'custom', '0', '0', '0', '_1576.png', '', '', '', '', '0', '', '', '', '0', '', '0', '0', '0', '0')Код: Выделить всё
#0 /var/www/lib/mysqli.class.php(400): custom_error->__construct('1366: Incorrect...', 0)
#1 /var/www/lib/mysqli.class.php(189): mysql->Error('INSERT INTO `co...', 0)
#2 /var/www/lib/mysqli.class.php(333): mysql->Exec('INSERT INTO `co...')
#3 /var/www/lib/sqlFunctions.class.php(111): mysql->Insert('commands', Array)
#4 /var/www/modules/commands/commands_edit.inc.php(172): SQLInsert('commands', Array)
#5 /var/www/modules/commands/commands.class.php(573): require('/var/www/module...')
#6 /var/www/modules/commands/commands.class.php(497): commands->edit_commands(Array, '')
#7 /var/www/modules/commands/commands.class.php(94): commands->admin(Array)
#8 /var/www/lib/jTemplate.class.php(713) : eval()'d code(8): commands->run()
#9 /var/www/lib/jTemplate.class.php(713): eval()
#10 /var/www/lib/jTemplate.class.php(195): jTemplate->parseModules('...', Array, './templates/')
#11 /var/www/lib/jTemplate.class.php(109): jTemplate->parse('...', Array, './templates/')
#12 /var/www/lib/parser.class.php(93): jTemplate->__construct('./templates/pan...', Array, Object(panel))
#13 /var/www/lib/parser.class.php(63): parser->jtemplate_parse('./templates/pan...', Array)
#14 /var/www/modules/panel.class.php(204): parser->__construct('./templates/pan...', Array, Object(panel))
#15 /var/www/admin.php(34): panel->run()
#16 {main}
