Страница 1 из 1
включение логов
Добавлено: Сб ноя 10, 2018 7:08 pm
victornguyen
Table Tennis Rackets - A Fun Way to Beat Your Friends With Long Pimple Rubbers
Introduced:
Maybe we all have picked up a table tennis ball or playing table tennis at some stage in our lives, or in the basement, garage, at school or at work. There are always a couple of too enthusiastic characters out there that play just to win, and make fun of people they beat. Well, if you were at the end of the receipt of ' misuse ' this, this tutorial might just be for you. This guide is for the normal players, already having some basic skills in the table tennis, which can create a little rotating ball but don't treat it enough seriously to play in the clubs. It uses two different types of rubber that you can put on either side of your bat, which very few ordinary players understand. Choose ping pong table outdoor to experience the most comfortable game.
Basic things:
The key to making this strategy job is to turn around and deceive, with your opponent does not know what type of spin on the ball. This often leads to your opponent losing the ball altogether, or hitting it in the grid or on the table.
The basic equipment you need for this strategy is a racquet with 2 fully contrasting rubber on the sides, a very sticky rubber (and sticky) (such as most Chinese rubber) and latex ' long acne '. Spinny Latex is obviously very good to create spin, while long acne latex is unique in that it returns most spins of your opponent back to him. These types of rubber can be purchased fairly cheaply at some online stores, such as One of a Kind Trading in Australia for instance. A couple of recommendations are given at the end of this article. Blades (bats without rubber) are not very important for this strategy to succeed, as rubber do most of the work. So if you don't yet have a blade, you can buy a cheap one from the same store, and they'll usually put it together for you for free.
Technically, you need a red and a black latex on either side of the paddle. However this is really just a requirement to compete, so if you just play casually then this is not necessary. To be completely cruel and make it more difficult for your opponent, you can have the same latex color on both sides, so that he cannot evaluate which one you are colliding. Because spin turns out of two different rubber is very different, hitting the ball with a side followed by a hit from the other side will generate very different results, leaving your opponent completely confused. However most casual players don't even look at what side you fight with, so it might not be a great advantage.
Put it into practice:
Ok, so you've got your new ' evil ' weapon, do you use any strategy to make the most of it? There are also two parts of this (1) when you serve (2) when you get:
1. When you serve: Put as many backspin and/or side-spin on the ball with your sticky rubber by hitting the ball with an action ahead below (and leaning for side-spin). With these rubber types much easier to do, but will still practice a bit. This will probably win you a few points altogether, but some will return. When it comes back, it will always have a substantial turning back, or your own, or spinning that your opponent convey. Hit the next blow with long acne rubber, do not hit the strongest or try to attack it, but try to keep it as low as possible but make sure it's on the table. The long acne rubber will really reverse the spin that is geared to you, which will produce very unpredictable bounses and balls. Chances are your opponent will miss the ball, or turn it up high so you can put the next person away, so be ready. If he returns it, continue the rally by rotating your sticky rubber ball, or gently return your acne latex. Start Looking for a few new best ping pong table At https://medium.com/@pingpongstart/best- ... 93d906ac74
If you find your opponent is good enough to get acquainted with your Spinney served, and adjust to it, do a similar looking serve with your long acne latex, and enjoy the results. Your opponent will adjust to the spin that is no, and this will force the bugs or balls easy to put away.
2. When you get: If your opponent uses a lot of spin in his serve, try and return them all with long acne latex. This will return most of his own back, and will get in trouble. If he's served with very little spin, try and bounce it with your Spinney rubber if you can. If he returns this, some spins will be returned to you, so you hit the next one with your long acne latex, and try and tie another bug.
The conclusion section:
Now I'm not saying this will be really easy, as it will take you a little time to learn how to use rubber, and adjust them. It would be best to have some practice with bats against some other players to tune them, before you embark on your task of ' destroying the bully '. Note that the long-term acne rubber attack is not recommended, because this technique is more advanced, but to block and cut them fairly easy to use at every level.
This type of racquet and strategy is actually used in high-level competition, and is even used by a few of the top players in the world. However, at higher levels, it takes a lot of skill and practice to be effective, and the simple strategies presented here are simply ineffective. This style of play adds another aspect to the game escape and can be very interesting at every level. There are many different types of rubber, and tongue, all of which have several different traits and require a number of different strategies. There are a lot of bats than what is mentioned here, and more strategies can be used. If you've already liked this guide, or want to read more about the rubber or other strategies, you can visit the website or forum of the author for more information. Read more ping pong playing robot pingpongstart.com
Re: включение логов
Добавлено: Пн ноя 12, 2018 1:36 am
victornguyen писал(а): Сб ноя 10, 2018 7:08 pm Можно ли как то отследить откуда запускается скрипт? (вэб компа, сенсор, пульт, с какого айпи, из какого приложения)
Это вряд ли. Не встречал ничего подобного.
victornguyen писал(а): Сб ноя 10, 2018 7:08 pm в принципе всё исключил, кроме кнопки в сценарии, но так и не понял где и как она сама нажимается
Сама себя она, конечно, не нажмет. ) А шаблоны поведения смотрел? М.б. у тебя на сообщения в чате что-то срабатывает.
Re: включение логов
Добавлено: Вт ноя 13, 2018 4:55 pm
описание ситуации не айс, но возможно такое поможет? (предварительно из разных мест настроить передачу параметров)
как пример
//$params['PROPERTY']
//$params['SOURCE']
//$params['OLD_VALUE']
//$params['NEW_VALUE']
$security = getGlobal('SecurityArmedMode.active');
if ($security == 1) {
 file_put_contents('./cms/texts/Presence.txt', date('Y-m-d H:i:s') . ' Режим охрана: ' . $params['PROPERTY'] . ' ' . $params['SOURCE'] . PHP_EOL, FILE_APPEND);
 return;
