Страница 1 из 1
Проблема cycle.php
Добавлено: Чт дек 20, 2012 1:47 pm
kdsystem
Собственно что-то не так.
подскажите плиз куда порыть?
root@brain:/var/www# php cycle.php
PHP Notice: Undefined index: COMPUTERNAME in /var/www/config.php on line 24
PHP Notice: Undefined index: S2G_SERVER_DOCROOT in /var/www/config.php on line 31
PHP Notice: Undefined index: S2G_BASE_URL in /var/www/config.php on line 39
PHP Notice: Undefined index: SERVER_NAME in /var/www/config.php on line 48
PHP Notice: Undefined index: REQUEST_URI in /var/www/lib/loader.php on line 15
PHP Notice: Undefined index: REQUEST_METHOD in /var/www/lib/general.class.php on line 48
PHP Notice: Undefined index: REQUEST_METHOD in /var/www/lib/general.class.php on line 74
CONNECTED TO DB
Running startup maintenance
admin_users ...OK
btdevices ...OK
calendar_categories ...OK
calendar_events ...OK
classes ...OK
collections ...OK
commands ...OK
elements ...OK
elm_states ...OK
events ...OK
gpsactions ...OK
gpsdevices ...OK
gpslocations ...OK
gpslog ...OK
history ...OK
jobs ...OK
layouts ...OK
locations ...OK
media_favorites ...OK
methods ...OK
newsletter ...OK
objects ...OK
owdevices ...OK
owdisplays ...OK
owproperties ...OK
patterns ...OK
phistory ...OK
pinghosts ...OK
prod_categories ...OK
product_categories ...OK
product_codes ...OK
product_log ...OK
products ...OK
project_modules ...OK
properties ...OK
pvalues ...OK
rss_channels ...OK
rss_items ...OK
safe_execs ...OK
scenes ...OK
script_categories ...OK
scripts ...OK
settings ...OK
shoplist ...OK
shopping_list_items ...OK
shoutrooms ...OK
shouts ...OK
tdwiki ...OK
terminals ...OK
usbdevices ...OK
userlog ...OK
users ...OK
watchfolders ...OK
webvars ...OK
Starting ./scripts/cycle_watchfolders.php ... OK
Starting ./scripts/cycle_main.php ... OK
Starting ./scripts/cycle_states.php ... OK
Starting ./scripts/cycle_execs.php ... OK
Starting ./scripts/cycle_webvars.php ... OK
Starting ./scripts/cycle_bluetooth.php ... OK
Starting ./scripts/cycle_ping.php ... OK
Starting ./scripts/cycle_onewire.php ... OK
Starting ./scripts/cycle_rss.php ... OK
Starting ./scripts/cycle_skype.php ... OK
Starting ./scripts/cycle_scheduler.php ... OK
Starting ./scripts/cycle_onewire_starred.php ... OK
ALL CYCLES STARTED
14:44:13 running cycle_main.php
PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_main.php on line 33
14:44:13 running cycle_watchfolders.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_watchfolders.php on line 25
14:44:13 running cycle_execs.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_execs.php on line 22
14:44:13 running cycle_states.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_states.php on line 23
PHP Notice: Undefined offset: 0 in /var/www/lib/objects.class.php on line 43
14:44:13 running cycle_webvars.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_webvars.php on line 24
14:44:13 running cycle_ping.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_ping.php on line 24
Checking www.ya.ru
PHP Warning: file_get_contents(www.ya.ru): failed to open stream: No such file or directory in /var/www/modules/pinghosts/pinghosts.class.php on line 217
PHP Warning: fopen(./cached/host_8.html): failed to open stream: No such file or directory in /var/www/lib/general.class.php on line 153
14:44:13 running cycle_scheduler.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_scheduler.php on line 22
14:44:13 Closing thread: php -q ./scripts/cycle_main.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 Closing thread: php -q ./scripts/cycle_execs.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 running cycle_rss.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_rss.php on line 24
14:44:13 Closing thread: php -q ./scripts/cycle_watchfolders.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 Closing thread: php -q ./scripts/cycle_bluetooth.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 running cycle_onewire.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_onewire.php on line 29
Checking device: 28.EDD2D5030000
14:44:13 Closing thread: php -q ./scripts/cycle_webvars.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 Closing thread: php -q ./scripts/cycle_ping.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 Closing thread: php -q ./scripts/cycle_scheduler.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 Closing thread: php -q ./scripts/cycle_rss.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 running cycle_onewire_starred.php
PHP Notice: Undefined variable: updated_time in /var/www/scripts/cycle_onewire_starred.php on line 29
14:44:13 Closing thread: php -q ./scripts/cycle_skype.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 Closing thread: php -q ./scripts/cycle_states.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 Closing thread: php -q ./scripts/cycle_onewire_starred.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
14:44:13 Closing thread: php -q ./scripts/cycle_onewire.php --params "a:0:{}"PHP Notice: Undefined variable: result in /var/www/lib/threads.php on line 83
Re: Проблема cycle.php
Добавлено: Чт дек 20, 2012 2:48 pm
Для начала нужно отключить NOTICE в php.ini -- они совершенно ни к чему.
А вот почему процессы циклов вдруг закрываются сами, тут я не вижу... Попробуй для начала всё-таки убрать NOTICE и запустить.
Добавлено: Чт дек 20, 2012 3:01 pm
kdsystem
apache2
исправил в /etc/php5/apache2/php.ini
error_reporting = E_ALL & ~E_DEPRECATED
на
error_reporting = E_ALL & ~E_NOTICE
перестартовал апач
нотисы так и сыпятся
Добавлено: Чт дек 20, 2012 4:43 pm
raptorialfungus
kdsystem писал(а): перестартовал апач
Поиском данный нюанс легко находится.
Надо "в /etc/php5/apache2/php.ini и /etc/php5/cli/php.ini установить
error_reporting = E_ALL & ~E_NOTICE & ~E_DEPRECATED
чтобы не заваливало ненужными сообщениями в логах"
Андрей
Добавлено: Пт дек 21, 2012 9:43 am
kdsystem
спасибо, но как проверить, что скрипты опрашивают 1wire и записывают в БД?
Добавлено: Пт дек 21, 2012 10:10 am
raptorialfungus
kdsystem писал(а):спасибо, но как проверить, что скрипты опрашивают 1wire и записывают в БД?
1. Зайти в админку
2. Зайти в раздел 1-Wire
3. Сканировать устройства
4. Если устройства обнаружены, то зайти в режим редактирования какого-то 1-Wire-устройства, установить небольшой интервал проверки
5. Выйти в список 1-Wire устройств
6. Убедиться, что поля Last check, Next check меняются с периодичностью, указанной в пункте 4.
7. Связать один из параметров 1-Wire устройства (например, temperature) с каким-то объектом и его свойством (например, ThisComputer.temperature)
8. Зайти в X-Ray /popup/xray.html
9. Убедиться, что ThisComputer.temperature обновляется с периодичностью, указанной в пункте 4.
Добавлено: Пт дек 21, 2012 10:29 am
kdsystem
по сути я понял, что у меня проблема в п.7
как они связываются?
в x-ray ничего не менятся и у других свойств.
Добавлено: Пт дек 21, 2012 10:42 am
raptorialfungus
kdsystem писал(а):по сути я понял, что у меня проблема в п.7
В настройках каждого 1-Wire-устройства. Справа от параметра есть два пустых поля: имя объекта и имя свойства. В моем примере ThisComputer - это объект, temperature - это свойство.
Добавлено: Пт дек 21, 2012 10:45 am
raptorialfungus
kdsystem писал(а):в x-ray ничего не менятся и у других свойств.
В X-Ray, я так понимаю, должно меняться как минимум свойство ClockChime.time. Если даже оно не меняется каждую минуту, то точняк скрипты не работают.
