Добрый вечер форумчяни. Нужна ваша помошь. Неделю пытаюсь установить мега сервер (по покрышкам стучал , фары протирал
) лезит кучя ошибок драва бросил(в библиотеку) а (библиотекарша) ругается что книг нету
(1.0.1)
arduino_mega_server.cpp:1276:23: warning: Ethernet2.h: No such file or directory
arduino_mega_server.cpp:1279:26: warning: EthernetUdp2.h: No such file or directory
arduino_mega_server.cpp:1280:21: warning: Twitter.h: No such file or directory
arduino_mega_server.cpp: In function 'void setup()':
arduino_mega_server.cpp:301: warning: only initialized variables can be placed into program memory area
arduino_mega_server.cpp:332: warning: only initialized variables can be placed into program memory area
arduino_mega_server.cpp:334: warning: only initialized variables can be placed into program memory area
arduino_mega_server.cpp:337: warning: only initialized variables can be placed into program memory area
arduino_mega_server.cpp: In function 'void loop()':
arduino_mega_server.cpp:420: warning: comparison between signed and unsigned integer expressions
arduino_mega_server:283: error: 'freqWorks' was not declared in this scope
arduino_mega_server:287: error: 'freqWorks' was not declared in this scope
arduino_mega_server.cpp: In function 'void electroWorks()':
arduino_mega_server.cpp:714: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendReqSensorFloat(char*, float)':
arduino_mega_server.cpp:1256: warning: format '%F' expects type 'double', but argument 4 has type 'float'
arduino_mega_server.cpp: At global scope:
mega:45: error: redefinition of 'byte modulRtc'
arduino_mega_server:50: error: 'byte modulRtc' previously defined here
mega:46: error: redefinition of 'byte modulEthernet'
arduino_mega_server:51: error: 'byte modulEthernet' previously defined here
mega:47: error: redefinition of 'byte modulSdCard'
arduino_mega_server:52: error: 'byte modulSdCard' previously defined here
mega:48: error: redefinition of 'byte modulServer'
arduino_mega_server:53: error: 'byte modulServer' previously defined here
mega:49: error: redefinition of 'byte modulMajor'
arduino_mega_server:54: error: 'byte modulMajor' previously defined here
mega:50: error: redefinition of 'byte modulLaurent'
arduino_mega_server:55: error: 'byte modulLaurent' previously defined here
mega:51: error: redefinition of 'byte modulPing'
arduino_mega_server:56: error: 'byte modulPing' previously defined here
mega:52: error: redefinition of 'byte modulUpload'
arduino_mega_server:57: error: 'byte modulUpload' previously defined here
mega:53: error: redefinition of 'byte modulPirs'
arduino_mega_server:58: error: 'byte modulPirs' previously defined here
mega:54: error: redefinition of 'byte modulContacts'
arduino_mega_server:59: error: 'byte modulContacts' previously defined here
mega:55: error: redefinition of 'byte modulTemp'
arduino_mega_server:60: error: 'byte modulTemp' previously defined here
mega:56: error: redefinition of 'byte modulElectro'
arduino_mega_server:61: error: 'byte modulElectro' previously defined here
mega:57: error: redefinition of 'byte modulLeds'
arduino_mega_server:62: error: 'byte modulLeds' previously defined here
mega:58: error: redefinition of 'byte modulKeys'
arduino_mega_server:63: error: 'byte modulKeys' previously defined here
mega:61: error: redefinition of 'char buf [200]'
arduino_mega_server:66: error: 'char buf [200]' previously declared here
mega:64: error: redefinition of 'time_t prevEventElectroCycle'
arduino_mega_server:90: error: 'time_t prevEventElectroCycle' previously declared here
mega:65: error: redefinition of 'time_t prevEventMegaLive'
arduino_mega_server:91: error: 'time_t prevEventMegaLive' previously declared here
mega:67: error: redefinition of 'char fn [20]'
arduino_mega_server:94: error: 'char fn [20]' previously defined here
mega:68: error: redefinition of 'char SELF_NAME []'
arduino_mega_server:95: error: 'char SELF_NAME [5]' previously defined here
mega:70: error: redefinition of 'byte MODE_SERVER'
arduino_mega_server:97: error: 'byte MODE_SERVER' previously defined here
mega:71: error: redefinition of 'byte MODE_UPDATE'
arduino_mega_server:98: error: 'byte MODE_UPDATE' previously defined here
mega:72: error: redefinition of 'byte mode'
arduino_mega_server:99: error: 'byte mode' previously declared here
mega:74: error: redefinition of 'boolean LED_state [4]'
arduino_mega_server:101: error: 'boolean LED_state [4]' previously defined here
mega:75: error: redefinition of 'boolean LED_state2 [4]'
arduino_mega_server:102: error: 'boolean LED_state2 [4]' previously defined here
mega:76: error: redefinition of 'boolean buttonElectro'
arduino_mega_server:103: error: 'boolean buttonElectro' previously defined here
mega:79: error: redefinition of 'long unsigned int timeSec'
arduino_mega_server:107: error: 'long unsigned int timeSec' previously declared here
mega:80: error: redefinition of 'long unsigned int timer1s'
arduino_mega_server:108: error: 'long unsigned int timer1s' previously declared here
mega:80: error: redefinition of 'boolean cycle1s'
arduino_mega_server:108: error: 'boolean cycle1s' previously defined here
mega:81: error: redefinition of 'long unsigned int timer4s'
arduino_mega_server:109: error: 'long unsigned int timer4s' previously declared here
mega:81: error: redefinition of 'boolean cycle4s'
arduino_mega_server:109: error: 'boolean cycle4s' previously defined here
mega:82: error: redefinition of 'long unsigned int timer20s'
arduino_mega_server:110: error: 'long unsigned int timer20s' previously declared here
mega:82: error: redefinition of 'boolean cycle20s'
arduino_mega_server:110: error: 'boolean cycle20s' previously defined here
mega:83: error: redefinition of 'long unsigned int timer30s'
arduino_mega_server:111: error: 'long unsigned int timer30s' previously declared here
mega:83: error: redefinition of 'boolean cycle30s'
arduino_mega_server:111: error: 'boolean cycle30s' previously defined here
mega:84: error: redefinition of 'long unsigned int timer1m'
arduino_mega_server:112: error: 'long unsigned int timer1m' previously declared here
mega:84: error: redefinition of 'boolean cycle1m'
arduino_mega_server:112: error: 'boolean cycle1m' previously defined here
mega:85: error: redefinition of 'long unsigned int timer3m'
arduino_mega_server:113: error: 'long unsigned int timer3m' previously declared here
mega:85: error: redefinition of 'boolean cycle3m'
arduino_mega_server:113: error: 'boolean cycle3m' previously defined here
mega:86: error: redefinition of 'long unsigned int timer5m'
arduino_mega_server:114: error: 'long unsigned int timer5m' previously declared here
mega:86: error: redefinition of 'boolean cycle5m'
arduino_mega_server:114: error: 'boolean cycle5m' previously defined here
mega:87: error: redefinition of 'int startSendTime'
arduino_mega_server:115: error: 'int startSendTime' previously defined here
mega:90: error: redefinition of 'File SDroot'
arduino_mega_server:118: error: 'File SDroot' previously declared here
mega:91: error: redefinition of 'File SDdir'
arduino_mega_server:119: error: 'File SDdir' previously declared here
mega:92: error: redefinition of 'File entry'
arduino_mega_server:120: error: 'File entry' previously declared here
mega:93: error: redefinition of 'Sd2Card card'
arduino_mega_server:121: error: 'Sd2Card card' previously declared here
mega:94: error: redefinition of 'SdVolume volume'
arduino_mega_server:122: error: 'SdVolume volume' previously declared here
mega:95: error: redefinition of 'SdFile root'
arduino_mega_server:123: error: 'SdFile root' previously declared here
mega:96: error: redefinition of 'const int chipSelect'
arduino_mega_server:124: error: 'const int chipSelect' previously defined here
mega:101: error: redefinition of 'const int LED_EMPTY'
arduino_mega_server:129: error: 'const int LED_EMPTY' previously defined here
mega:102: error: redefinition of 'const int LED_PIR_01'
arduino_mega_server:130: error: 'const int LED_PIR_01' previously defined here
mega:103: error: redefinition of 'const int LED_ANALOG_01'
arduino_mega_server:131: error: 'const int LED_ANALOG_01' previously defined here
mega:104: error: redefinition of 'int MODE'
arduino_mega_server:132: error: 'int MODE' previously defined here
mega:110: error: redefinition of 'void setup()'
arduino_mega_server:157: error: 'void setup()' previously defined here
arduino_mega_server.cpp:1389: warning: only initialized variables can be placed into program memory area
mega:193: error: redefinition of 'void loop()'
arduino_mega_server:239: error: 'void loop()' previously defined here
arduino_mega_server.cpp:1509: warning: comparison between signed and unsigned integer expressions
arduino_mega_server.cpp: In function 'void pirsWorks()':
arduino_mega_server.cpp:1651: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1660: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1671: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1680: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1711: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1720: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1731: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1740: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1750: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:1759: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void SDcardInit()':
arduino_mega_server.cpp:1972: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void serverWorks()':
arduino_mega_server.cpp:2167: warning: array subscript has type 'char'
arduino_mega_server.cpp:2181: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendXMLtitle(EthernetClient)':
arduino_mega_server.cpp:2275: warning: only initialized variables can be placed into program memory area
arduino_mega_server.cpp: In function 'void parseRequest(EthernetClient)':
arduino_mega_server.cpp:2326: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2330: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2336: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2351: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2352: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2353: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2354: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2355: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2366: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2371: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2375: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2379: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2384: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2388: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2392: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendContacts(EthernetClient)':
arduino_mega_server.cpp:2400: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2401: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendFreeRAM(EthernetClient)':
arduino_mega_server.cpp:2406: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendPirs(EthernetClient)':
arduino_mega_server.cpp:2411: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2412: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2413: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2414: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2415: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2416: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendElectro(EthernetClient)':
arduino_mega_server.cpp:2422: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2423: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2424: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2425: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2426: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2427: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2428: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2429: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2430: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2431: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2432: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2433: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2434: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2435: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendEventsList(EthernetClient)':
arduino_mega_server.cpp:2441: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2442: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2443: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2444: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2445: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2446: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2447: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2448: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2449: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2450: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendModules(EthernetClient)':
arduino_mega_server.cpp:2455: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2456: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2457: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2458: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2459: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2460: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2461: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2462: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2463: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2464: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2465: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2466: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2467: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2468: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendDigitalPorts(EthernetClient)':
arduino_mega_server.cpp:2472: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2473: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2474: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2475: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2476: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2477: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2478: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2479: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2480: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2481: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2482: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2483: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2484: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2485: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2486: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2487: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2488: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendUptime(EthernetClient)':
arduino_mega_server.cpp:2492: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2493: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void sendCPUload(EthernetClient)':
arduino_mega_server.cpp:2532: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2533: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void SetLEDs()':
arduino_mega_server.cpp:2583: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2586: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2592: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2595: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2601: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2604: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2610: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2613: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void responseNetwork(EthernetClient)':
arduino_mega_server.cpp:2682: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2683: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2684: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2685: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2686: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2687: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2688: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2689: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2690: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2691: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void SetLEDs_electro()':
arduino_mega_server.cpp:2715: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2718: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2724: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2727: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2734: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2737: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2744: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2747: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void responseElectroControl(EthernetClient)':
arduino_mega_server.cpp:2760: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void responseElectro(EthernetClient)':
arduino_mega_server.cpp:2790: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void responseSDcard(EthernetClient)':
arduino_mega_server.cpp:2802: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2804: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2805: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2806: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'void responseDash(EthernetClient)':
arduino_mega_server.cpp:2822: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2838: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp:2839: warning: deprecated conversion from string constant to 'char*'
arduino_mega_server.cpp: In function 'char StrContains(char*, char*)':
arduino_mega_server.cpp:2967: warning: comparison between signed and unsigned integer expressions
arduino_mega_server.cpp:2970: warning: array subscript has type 'char'
arduino_mega_server.cpp:2972: warning: comparison between signed and unsigned integer expressions
