Обновись, ну или внеси изменения.
<?php
* Summary of sayReply
* @param mixed $ph Phrase
* @param mixed $level Level (default 0)
* @param mixed $replyto Original request
* @return void
function sayReply($ph, $level = 0, $replyto='') {
$source='';
if ($replyto) {
$terminal_rec=SQLSelectOne("SELECT * FROM terminals WHERE LATEST_REQUEST LIKE '%".DBSafe($replyto)."%' ORDER BY LATEST_REQUEST_TIME DESC LIMIT 1");
$orig_msg=SQLSelectOne("SELECT * FROM shouts WHERE SOURCE!='' AND MESSAGE LIKE '%".DBSafe($replyto)."%' AND ADDED>=(NOW() - INTERVAL 30 SECOND) ORDER BY ADDED DESC LIMIT 1");
if ($orig_msg['ID']) {
$source=$orig_msg['SOURCE'];
$terminal_rec=SQLSelectOne("SELECT * FROM terminals WHERE LATEST_REQUEST_TIME>=(NOW() - INTERVAL 5 SECOND) ORDER BY LATEST_REQUEST_TIME DESC LIMIT 1");
if (!$terminal_rec) {
say($ph, $level);
$source='terminal'.$terminal_rec['ID'];
$said_status=sayTo($ph, $level, $terminal_rec['NAME']);
if (!$said_status) {
say($ph, $level);
$rec = array();
$rec['MESSAGE'] = $ph;
$rec['ADDED'] = date('Y-m-d H:i:s');
$rec['ROOM_ID'] = 0;
$rec['MEMBER_ID'] = 0;
if ($level > 0) $rec['IMPORTANCE'] = $level;
$rec['ID'] = SQLInsert('shouts', $rec);
processSubscriptions('SAYREPLY', array('level' => $level, 'message' => $ph, 'replyto' => $replyto, 'source'=>$source));
* Summary of sayTo
* @param mixed $destination Destination terminal name
* @return void
function sayTo($ph, $level = 0, $destination = '') {
if (!$destination) {
return 0;
$processed=processSubscriptions('SAYTO', array('level' => $level, 'message' => $ph, 'destination' => $destination));
$terminal_rec=SQLSelectOne("SELECT * FROM terminals WHERE NAME LIKE '".DBSafe($destination)."'");
if ($terminal_rec['LINKED_OBJECT'] && $terminal_rec['LEVEL_LINKED_PROPERTY']) {
$min_level=(int)getGlobal($terminal_rec['LINKED_OBJECT'].'.'.$terminal_rec['LEVEL_LINKED_PROPERTY']);
$min_level=(int)getGlobal('minMsgLevel');
if ($level < $min_level) {
return 0;
if ($terminal_rec['MAJORDROID_API'] && $terminal_rec['HOST']) {
$service_port='7999';
$in='tts:'.$ph;
$address=$terminal_rec['HOST'];
if (!preg_match('/^\d/',$address)) return 0;
$socket = socket_create(AF_INET, SOCK_STREAM, SOL_TCP);
if ($socket === false) {
return 0;
$result = socket_connect($socket, $address, $service_port);
if ($result === false) {
return 0;
socket_write($socket, $in, strlen($in));
socket_close($socket);
return 1;
} elseif (!$processed) {
//say($ph,$level);
return 0;
return 0;
* Summary of say
* @param mixed $member_id Member ID (default 0)
* @return void
function say($ph, $level = 0, $member_id = 0, $source = '')
global $noPatternMode;
global $ignoreVoice;
verbose_log("SAY (level: $level; member: $member; source: $source): ".$ph);
$rec = array();
$rec['MEMBER_ID'] = $member_id;
$rec['SOURCE'] = $source;
if ($member_id)
$processed=processSubscriptions('COMMAND', array('level' => $level, 'message' => $ph, 'member_id' => $member_id));
if (!$processed) {
include_once(DIR_MODULES . 'patterns/patterns.class.php');
$pt = new patterns();
$res=$pt->checkAllPatterns($member_id);
processCommand($ph);
return;
if (defined('SETTINGS_HOOK_BEFORE_SAY') && SETTINGS_HOOK_BEFORE_SAY != '')
eval(SETTINGS_HOOK_BEFORE_SAY);
if ($level >= (int)getGlobal('minMsgLevel') && !$ignoreVoice && !$member_id)
if (!defined('SETTINGS_SPEAK_SIGNAL') || SETTINGS_SPEAK_SIGNAL == '1')
$passed = time() - (int)getGlobal('lastSayTime');
if ($passed > 20)
playSound('dingdong', 1, $level);
setGlobal('lastSayTime', time());
setGlobal('lastSayMessage', $ph);
processSubscriptions('SAY', array('level' => $level, 'message' => $ph, 'member_id' => $member_id, 'ignoreVoice'=>$ignoreVoice));
if (!$noPatternMode)
if (defined('SETTINGS_HOOK_AFTER_SAY') && SETTINGS_HOOK_AFTER_SAY != '')
eval(SETTINGS_HOOK_AFTER_SAY);
$terminals=SQLSelect("SELECT NAME FROM terminals WHERE IS_ONLINE=1 AND MAJORDROID_API=1");
$total=count($terminals);
for($i=0;$i<$total;$i++) {
sayTo($ph, $level, $terminals[$i]['NAME']);
function ask($prompt, $target = '') {
processSubscriptions('ASK', array('prompt' => $prompt, 'target' => $target));
$in='ask:'.$prompt;
if (preg_match('/^[\d\.]+$/',$target)) {
if ($socket) {
$result = socket_connect($socket, $target, $service_port);
if ($result) {
$qry=1;
$qry.=" AND MAJORDROID_API=1";
$qry.=" AND (NAME LIKE '".DBSafe($target)."' OR TITLE LIKE '".DBSafe($target)."')";
$terminals = SQLSelect("SELECT * FROM terminals WHERE $qry");
$total = count($terminals);
for ($i = 0; $i < $total; $i++) {
$address = $terminals[$i]['HOST'];
if ($socket) {
if ($result) {
* Summary of processCommand
* @param mixed $command Command
* @return void
function processCommand($command)
global $pattern_matched;
if (!$pattern_matched)
getObject("ThisComputer")->callMethod("commandReceived", array("command" => $command));
* Summary of timeConvert
* @param mixed $tm Time
* @return int|string
function timeConvert($tm)
$tm = trim($tm);
if (preg_match('/^(\d+):(\d+)$/', $tm, $m))
$hour = $m[1];
$minute = $m[2];
$trueTime = mktime($hour, $minute, 0, (int)date('m'), (int)date('d'), (int)date('Y'));
elseif (preg_match('/^(\d+)$/', $tm, $m))
$trueTime = $tm;
return $trueTime;
function getNumberWord($number, $suffix) {
$keys = array(2, 0, 1, 1, 1, 2);
$mod = $number % 100;
$suffix_key = ($mod > 7 && $mod < 20) ? 2: $keys[min($mod % 10, 5)];
return $suffix[$suffix_key];
* Summary of timeNow
* @param mixed $tm time (default 0)
* @return string
function timeNow($tm = 0)
if (!$tm)
$tm = time();
$h = (int)date('G', $tm);
$m = (int)date('i', $tm);
$ms = '';
$language = SETTINGS_SITE_LANGUAGE;
if ($language == 'ru') {
$array = array("час", "часа", "часов");
$hw = $h.' '.getNumberWord($h,$array);
if ($m>0) {
$array = array("минута", "минуты", "минут");
$ms = $m.' '.getNumberWord($m,$array);
} elseif ($language == 'en' && $m == 0) {
$hw = $h.' o\'clock';
$hw = date('H:i',$tm);
$res = trim($hw . " " . $ms);
return $res;
* Summary of isWeekEnd
* @return bool
function isWeekEnd()
if (date('w') == 0 || date('w') == 6)
return true; // sunday, saturday
return false;
* Summary of isWeekDay
* @return bool
function isWeekDay()
if (IsWeekEnd())
return false;
return true;
* Summary of timeIs
* @return bool
function timeIs($tm)
if (date('H:i') == $tm)
return true;
return false;
* Summary of timeBefore
* @return bool
function timeBefore($tm)
$trueTime = timeConvert($tm);
if (time() <= $trueTime)
return true;
return false;
* Summary of timeAfter
* @return bool
function timeAfter($tm)
if (time() >= $trueTime)
return true;
return false;
* Summary of timeBetween
* @param mixed $tm1 Time 1
* @param mixed $tm2 Time 2
* @return bool
function timeBetween($tm1, $tm2)
$trueTime1 = timeConvert($tm1);
$trueTime2 = timeConvert($tm2);
if ($trueTime1 > $trueTime2)
if ($trueTime2 < time())
$trueTime2 += 24 * 60 * 60;
else
$trueTime1 -= 24 * 60 * 60;
if ((time() >= $trueTime1) && (time() <= $trueTime2))
return true;
return false;
* Summary of addScheduledJob
* @param mixed $title Title
* @param mixed $commands Commands
* @param mixed $datetime Date
* @param mixed $expire Expire time (default 60)
* @return mixed
function addScheduledJob($title, $commands, $datetime, $expire = 1800)
$rec = array();
$rec['TITLE'] = $title;
$rec['COMMANDS'] = $commands;
$rec['RUNTIME'] = date('Y-m-d H:i:s', $datetime);
$rec['EXPIRE'] = date('Y-m-d H:i:s', $datetime + $expire);
$rec['ID'] = SQLInsert('jobs', $rec);
return $rec['ID'];
* Summary of clearScheduledJob
* @return void
function clearScheduledJob($title)
SQLExec("DELETE FROM jobs WHERE TITLE LIKE '" . DBSafe($title) . "'");
* Delete job from schedule
* @param mixed $id Job id
* @return void
function deleteScheduledJob($id)
SQLExec("DELETE FROM jobs WHERE ID = " . (int)$id);
* Summary of setTimeOut
* @param mixed $timeout Timeout
* @return mixed
function setTimeOut($title, $commands, $timeout)
clearTimeOut($title);
$res=addScheduledJob($title, $commands, time() + $timeout);
return $res;
* Summary of clearTimeOut
* @return void
function clearTimeOut($title)
return clearScheduledJob($title);
* Summary of timeOutExists
* @return int
function timeOutExists($title)
$job = SQLSelectOne("SELECT ID FROM jobs WHERE PROCESSED = 0 AND TITLE LIKE '" . DBSafe($title) . "'");
return (int)$job['ID'];
* Summary of runScheduledJobs
* @return void
function runScheduledJobs()
SQLExec("DELETE FROM jobs WHERE EXPIRE <= '" . date('Y-m-d H:i:s') . "'");
$sqlQuery = "SELECT *
FROM jobs
WHERE PROCESSED = 0
AND EXPIRED = 0
AND RUNTIME <= '" . date('Y-m-d H:i:s') . "'";
$jobs = SQLSelect($sqlQuery);
$total = count($jobs);
echo "Running job: " . $jobs[$i]['TITLE'] . "\n";
$jobs[$i]['PROCESSED'] = 1;
$jobs[$i]['STARTED'] = date('Y-m-d H:i:s');
SQLUpdate('jobs', $jobs[$i]);
if ($jobs[$i]['COMMANDS'] != '') {
$url = BASE_URL . '/objects/?job=' . $jobs[$i]['ID'];
$result = trim(getURL($url, 0));
$result = preg_replace('/<!--.+-->/is', '', $result);
if (!preg_match('/OK$/', $result)) {
//getLogger(__FILE__)->error(sprintf('Error executing job %s (%s): %s', $jobs[$i]['TITLE'], $jobs[$i]['ID'], $result));
DebMes(sprintf('Error executing job %s (%s): %s', $jobs[$i]['TITLE'], $jobs[$i]['ID'], $result) . ' (' . __FILE__ . ')');
* Summary of textToNumbers
* @param mixed $text Text
* @return mixed
function textToNumbers($text)
$newtext = ($text);
return $newtext;
* Summary of recognizeTime
* @param mixed $newText New text
* @return array|double|int
function recognizeTime($text, &$newText)
$result = 0;
$found = 0;
$new_time = time();
$text = ($text);
if (preg_match('/через (\d+) секунд.?/isu', $text, $m))
$new_time = time() + $m[1];
$newText = trim(str_replace($m[0], '', $text));
$found = 1;
elseif (preg_match('/через (\d+) минут.?/isu', $text, $m))
$new_time = time() + $m[1] * 60;
$found = 1;
elseif (preg_match('/через (\d+) час.?/isu', $text, $m))
$new_time = time() + $m[1] * 60 * 60;
$found = 1;
elseif (preg_match('/в (\d+):(\d+)/isu', $text, $m))
$new_time = mktime($m[1], $m[2], 0, (int)date('m'), (int)date('d'), (int)date('Y'));
$found = 1;
$newText = ($newText);
if ($found)
$result = $new_time;
return $result;
* Summary of registerEvent
* @param mixed $eventName Event name
* @param mixed $details Details (default '')
* @param mixed $expire_in Expire time (default 365)
* @return mixed
function registerEvent($eventName, $details = '', $expire_in = 0)
include_once(DIR_MODULES.'events/events.class.php');
$events = new events();
return $events->registerEvent($eventName, $details, $expire_in);
* Summary of registeredEventTime
* @return mixed
function registeredEventTime($eventName)
$sqlQuery = "SELECT ID, UNIX_TIMESTAMP(ADDED) as TM
FROM events
WHERE EVENT_TYPE = 'system'
AND EVENT_NAME = '" . DBSafe($eventName) . "'
ORDER BY ADDED DESC
LIMIT 1";
$rec = SQLSelectOne($sqlQuery);
if ($rec['ID'])
return $rec['TM'];
else
return -1;
* Summary of getRandomLine
* @param mixed $filename File name
* @return mixed
function getRandomLine($filename)
if (file_exists(ROOT . 'texts/' . $filename . '.txt'))
$filename = ROOT . 'texts/' . $filename . '.txt';
if (file_exists($filename))
$data = LoadFile($filename);
$data = str_replace("\r", '', $data);
$data = str_replace("\n\n", "\n", $data);
$lines = mb_split("\n", $data);
$total = count($lines);
$line = $lines[round(rand(0, $total - 1))];
if ($line != '')
return $line;
* Summary of playSound
* @param mixed $exclusive Exclusive (default 0)
* @param mixed $priority Priority (default 0)
* @return void
function playSound($filename, $exclusive = 0, $priority = 0)
global $ignoreSound;
if (file_exists(ROOT . 'sounds/' . $filename . '.mp3'))
$filename = ROOT . 'sounds/' . $filename . '.mp3';
elseif (file_exists(ROOT . 'sounds/' . $filename))
$filename = ROOT . 'sounds/' . $filename;
if (defined('SETTINGS_HOOK_BEFORE_PLAYSOUND') && SETTINGS_HOOK_BEFORE_PLAYSOUND != '')
eval(SETTINGS_HOOK_BEFORE_PLAYSOUND);
if (!$ignoreSound)
if (IsWindowsOS())
safe_exec(DOC_ROOT . '/rc/madplay.exe ' . $filename, $exclusive, $priority);
else
safe_exec('mplayer ' . $filename . " >/dev/null 2>&1", $exclusive, $priority);
if (defined('SETTINGS_HOOK_AFTER_PLAYSOUND') && SETTINGS_HOOK_AFTER_PLAYSOUND != '')
eval(SETTINGS_HOOK_AFTER_PLAYSOUND);
* Summary of playMedia
* @param mixed $path Path
* @param mixed $host Host (default 'localhost')
* @return int
function playMedia($path, $host = 'localhost')
if (defined('SETTINGS_HOOK_PLAYMEDIA') && SETTINGS_HOOK_PLAYMEDIA != '')
eval(SETTINGS_HOOK_PLAYMEDIA);
FROM terminals
WHERE HOST LIKE '" . DBSafe($host) . "'
OR NAME LIKE '" . DBSafe($host) . "'
OR TITLE LIKE '" . DBSafe($host) . "'";
$terminal = SQLSelectOne($sqlQuery);
if (!$terminal['ID'])
$terminal = SQLSelectOne("SELECT * FROM terminals WHERE CANPLAY = 1 ORDER BY ID");
$terminal = SQLSelectOne("SELECT * FROM terminals WHERE 1 ORDER BY ID");
return 0;
include_once(DIR_MODULES . 'app_player/app_player.class.php');
$player = new app_player();
$player->terminal_id = $terminal['ID'];
$player->play = $path;
global $ajax;
$ajax = 1;
global $command;
$command = 'refresh';
$player->intCall = 1;
$player->usual($out);
* Summary of runScript
* @param mixed $id ID
* @param mixed $params Params (default '')
* @return mixed
function runScript($id, $params = '')
include_once(DIR_MODULES . 'scripts/scripts.class.php');
$sc = new scripts();
return $sc->runScript($id, $params);
function runScriptSafe($id, $params = '') {
$current_call='script.'.$id;
$call_stack=array();
if (isset($_GET['m_c_s']) && is_array($_GET['m_c_s'])) {
$call_stack = $_GET['m_c_s'];
if (in_array($current_call,$call_stack)) {
$call_stack[]=$current_call;
DebMes("Warning: cross-linked call of ".$current_call."\nlog:\n".implode(" -> \n",$call_stack));
return 0;
$data=array(
'script'=>$id,
'm_c_s'=>$call_stack
$url=BASE_URL.'/objects/?'.http_build_query($data);
if (is_array($params)) {
foreach($params as $k=>$v) {
$url.='&'.$k.'='.urlencode($v);
$result = getURLBackground($url,0);
return $result;
* Summary of callScript
* @return void
function callScript($id, $params = '')
function getURLBackground($url, $cache = 0, $username = '', $password = '') {
getURL($url, $cache, $username, $password, true);
* Summary of getURL
* @param mixed $url Url
* @param mixed $cache Cache (default 0)
* @param mixed $username User name (default '')
* @param mixed $password Password (default '')
* @return mixed
function getURL($url, $cache = 0, $username = '', $password = '', $background = false)
$cache_file = ROOT . 'cached/urls/' . preg_replace('/\W/is', '_', str_replace('http://', '', $url)) . '.html';
if (!$cache || !is_file($cache_file) || ((time() - filemtime($cache_file)) > $cache))
try
//DebMes('Geturl started for '.$url. ' Source: ' .debug_backtrace()[1]['function'], 'geturl');
$startTime=getmicrotime();
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_USERAGENT, 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10.9; rv:32.0) Gecko/20100101 Firefox/32.0');
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, 5); // connection timeout
curl_setopt($ch, CURLOPT_MAXREDIRS, 2);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
curl_setopt($ch, CURLOPT_TIMEOUT, 45); // operation timeout 45 seconds
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false); // bad style, I know...
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, 2);
if ($background) {
curl_setopt($ch, CURLOPT_NOSIGNAL, 1);
curl_setopt($ch, CURLOPT_TIMEOUT_MS, 1000);
if ($username != '' || $password != '')
curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
curl_setopt($ch, CURLOPT_USERPWD, $username . ":" . $password);
$url_parsed=parse_url($url);
$host=$url_parsed['host'];
$use_proxy=false;
if (defined('USE_PROXY') && USE_PROXY!='') {
$use_proxy=true;
if ($host == '127.0.0.1' || $host == 'localhost') {
$use_proxy=false;
if ($use_proxy && defined('HOME_NETWORK') && HOME_NETWORK != '') {
$p = preg_quote(HOME_NETWORK);
$p = str_replace('\*', '\d+?', $p);
$p = str_replace(',', ' ', $p);
$p = str_replace(' ', ' ', $p);
$p = str_replace(' ', '|', $p);
if (preg_match('/' . $p . '/is', $host)) {
$use_proxy=false;
if ($use_proxy) {
curl_setopt($ch, CURLOPT_PROXY, USE_PROXY);
if (defined('USE_PROXY_AUTH') && USE_PROXY_AUTH!='') {
curl_setopt($ch, CURLOPT_PROXYUSERPWD, USE_PROXY_AUTH);
$tmpfname = ROOT . 'cached/cookie.txt';
curl_setopt($ch, CURLOPT_COOKIEJAR, $tmpfname);
curl_setopt($ch, CURLOPT_COOKIEFILE, $tmpfname);
$result = curl_exec($ch);
if (curl_errno($ch) && !$background) {
$errorInfo = curl_error($ch);
$info = curl_getinfo($ch);
$backtrace = debug_backtrace();
$callSource = $backtrace[1]['function'];
DebMes("GetURL to $url (source ".$callSource.") finished with error: \n".$errorInfo."\n".json_encode($info));
curl_close($ch);
catch (Exception $e)
registerError('geturl', $url . ' ' . get_class($e) . ', ' . $e->getMessage());
if ($cache > 0)
CreateDir(ROOT . 'cached/urls');
SaveFile($cache_file, $result);
else
$result = LoadFile($cache_file);
return $result;
* Summary of safe_exec
* @return mixed
function safe_exec($command, $exclusive = 0, $priority = 0)
$rec = array();
$rec['COMMAND'] = $command;
$rec['EXCLUSIVE'] = (int)$exclusive;
$rec['PRIORITY'] = (int)$priority;
$rec['ID'] = SQLInsert('safe_execs', $rec);
return $rec['ID'];
* Summary of execInBackground
* @param mixed $cmd Command
* @return void
function execInBackground($cmd)
if (IsWindowsOS())
//pclose(popen("start /B ". $cmd, "r"));
try
system($cmd);
//$WshShell = new COM("WScript.Shell");
//$oExec = $WshShell->Run("cmd /C ".$cmd, 0, false);
//exec($cmd);
DebMes('Error: exception ' . get_class($e) . ', ' . $e->getMessage() . '.');
else
exec($cmd . " > /dev/null &");
* Summary of getFilesTree
* @param mixed $sort Sort (default 'name')
* @return array
function getFilesTree($destination, $sort = 'name')
if (substr($destination, -1) == '/' || substr($destination, -1) == '\\')
$destination = substr($destination, 0, strlen($destination) - 1);
$res = array();
if (!is_dir($destination))
return $res;
if ($dir = @opendir($destination))
while (($file = readdir($dir)) !== false)
if (is_dir($destination . "/" . $file) && ($file != '.') && ($file != '..'))
$tmp = getFilesTree($destination . "/" . $file);
if (is_array($tmp))
foreach ($tmp as $elem)
$res[] = $elem;
elseif (is_file($destination . "/" . $file))
$res[] = ($destination . "/" . $file);
closedir($dir);
if ($sort == 'name')
sort($res, SORT_STRING);
return $res;
* Summary of isOnline
* @return int
function isOnline($host)
FROM pinghosts
WHERE HOSTNAME LIKE '" . DBSafe($host) . "'
if (!$rec['STATUS'] || $rec['STATUS'] == 2)
return 0;
else
return 1;
* Summary of checkAccess
* @param mixed $object_type Object type
* @param mixed $object_id Object ID
* @return bool
function checkAccess($object_type, $object_id)
include_once(DIR_MODULES . 'security_rules/security_rules.class.php');
$sc = new security_rules();
return $sc->checkAccess($object_type, $object_id);
* Summary of registerError
* @param mixed $code Code (default 'custom')
* @return void
function registerError($code = 'custom', $details = '')
$e = new \Exception;
$backtrace=$e->getTraceAsString();
DebMes("Error registered (type: $code):\n".$details."\nBacktrace:\n".$backtrace,'error');
$code = trim($code);
if ($code == 'sql') {
return 0;
$error_rec = SQLSelectOne("SELECT * FROM system_errors WHERE CODE LIKE '" . DBSafe($code) . "'");
if (!$error_rec['ID'])
$error_rec['CODE'] = $code;
$error_rec['KEEP_HISTORY'] = 1;
$error_rec['ID'] = SQLInsert('system_errors', $error_rec);
$error_rec['LATEST_UPDATE'] = date('Y-m-d H:i:s');
@$error_rec['ACTIVE'] = (int)$error_rec['ACTIVE'] + 1;
SQLUpdate('system_errors', $error_rec);
$history_rec = array();
$history_rec['ERROR_ID'] = $error_rec['ID'];
$history_rec['COMMENTS'] = $details."\nBacktrace:\n".$backtrace;
$history_rec['ADDED'] = $error_rec['LATEST_UPDATE'];
//Temporary disabled
$xrayUrl = BASE_URL . ROOTHTML.'popup/xray.html?ajax=1&md=xray&op=getcontent&view_mode=';
$history_rec['PROPERTIES_DATA'] = getURL($xrayUrl, 0);
$history_rec['METHODS_DATA'] = getURL($xrayUrl . 'methods', 0);
$history_rec['SCRIPTS_DATA'] = getURL($xrayUrl . 'scripts', 0);
$history_rec['TIMERS_DATA'] = getURL($xrayUrl . 'timers', 0);
$history_rec['EVENTS_DATA'] = getURL($xrayUrl . 'events', 0);
$history_rec['DEBUG_DATA'] = getURL($xrayUrl . 'debmes', 0);
$history_rec['ID'] = SQLInsert('system_errors_data', $history_rec);
if (!$error_rec['KEEP_HISTORY'])
SQLExec("DELETE FROM system_errors_data WHERE ID != '" . $history_rec['ID'] . "'");
* Возвращает true если ОС - Windows
* @return bool
function IsWindowsOS()
if (substr(php_uname(), 0, 7) === "Windows")
return true;
return false;
* Summary of makePayload
* @param mixed $data Data
* @return string
function makePayload($data)
$res = '';
foreach ($data as $v)
$res .= chr($v);
return $res;
* Summary of HexStringToArray
* @param mixed $buf Buffer
* @return array
function HexStringToArray($buf)
$res = array();
$bufLength = strlen($buf) - 1;
for ($i = 0; $i < $bufLength; $i += 2)
$res[] = (hexdec($buf[$i] . $buf[$i + 1]));
return $res;
* Summary of HexStringToString
* @return string
function HexStringToString($buf)
$res = '';
$res .= chr(hexdec($buf[$i] . $buf[$i + 1]));
return $res;
* Summary of binaryToString
* @return string
function binaryToString($buf)
$res = '';
$bufLength = strlen($buf);
for ($i = 0; $i < $bufLength; $i++)
$num = dechex(ord($buf[$i]));
if (strlen($num) == 1)
$num = '0' . $num;
$res .= $num;
return $res;
function verbose_log($data) {
if (defined('VERBOSE_LOG') && VERBOSE_LOG==1) {
if (defined('VERBOSE_LOG_IGNORE') && VERBOSE_LOG_IGNORE!='') {
$tmp=explode(',', VERBOSE_LOG_IGNORE);
$total=count($tmp);
$regex=trim($tmp[$i]);
if (preg_match('/'.$regex.'/is', $data)) {
return;
global $verbose_thread_id;
global $argv;
if (!isset($verbose_thread_id)) {
$verbose_thread_id = date('H:i:s').'_'.rand(1000,9999);
$cmd = '';
if ($_SERVER['REQUEST_URI']!='') {
$cmd = $_SERVER['REQUEST_METHOD'].' '.$_SERVER['REQUEST_URI'];
} elseif ($argv[0]!='') {
$cmd = implode(' ',$argv);
$verbose_thread_id.='_'.basename($argv[0]);
DebMes('th_'.$verbose_thread_id.' start '.$cmd,'verbose');
$bt = debug_backtrace();
$total_bt = count($bt);
$max_bt = 5;
//$bt = array_reverse($bt);
$bt = array_slice($bt,1,$max_bt);
$total = count($bt);
if ($total>0) {
$res_trace=array();
$res_trace[]=$bt[$i]['function'];
if ($total_bt>($max_bt+1)) {
$res_trace[]='...';
$data = $data . ' ('.implode('<',$res_trace).')';
DebMes('th_'.$verbose_thread_id.' '.$data,'verbose');
* Title
* @return string
function return_memory_usage() {
$size=memory_get_usage(true);
$unit=array('b','kb','mb','gb','tb','pb');
return @round($size/pow(1024,($i=floor(log($size,1024)))),2).' '.$unit[$i];
