* NUT
* @package project
* @author Ivan Z. <
[email protected]>
* @copyright
http://www.smartliving.ru/ (c)
* Ver: 0.2
include_once("nut.class.php");
class app_nut extends module {
* blank
* Module class constructor
* @access private
function app_nut() {
$this->name="app_nut";
$this->title="NUT";
$this->module_category="<#LANG_SECTION_DEVICES#>";
$this->checkInstalled();
* saveParams
* Saving module parameters
* @access public
function saveParams() {
$p=array();
if (IsSet($this->id)) {
$p["id"]=$this->id;
if (IsSet($this->view_mode)) {
$p["view_mode"]=$this->view_mode;
if (IsSet($this->edit_mode)) {
$p["edit_mode"]=$this->edit_mode;
if (IsSet($this->tab)) {
$p["tab"]=$this->tab;
return parent::saveParams($p);
* getParams
* Getting module parameters from query string
* @access public
function getParams() {
global $id;
global $mode;
global $view_mode;
global $edit_mode;
global $tab;
if (isset($id)) {
$this->id=$id;
if (isset($mode)) {
$this->mode=$mode;
if (isset($view_mode)) {
$this->view_mode=$view_mode;
if (isset($edit_mode)) {
$this->edit_mode=$edit_mode;
if (isset($tab)) {
$this->tab=$tab;
* Run
* Description
* @access public
function run() {
global $session;
$out=array();
if ($this->action=='admin') {
$this->admin($out);
$this->usual($out);
if (IsSet($this->owner->action)) {
$out['PARENT_ACTION']=$this->owner->action;
if (IsSet($this->owner->name)) {
$out['PARENT_NAME']=$this->owner->name;
$out['VIEW_MODE']=$this->view_mode;
$out['EDIT_MODE']=$this->edit_mode;
$out['MODE']=$this->mode;
$out['ACTION']=$this->action;
if ($this->single_rec) {
$out['SINGLE_REC']=1;
$this->data=$out;
$p=new parser(DIR_TEMPLATES.$this->name."/".$this->name.".html", $this->data, $this);
$this->result=$p->result;
* BackEnd
* Module backend
* @access public
function admin(&$out) {
if ($this->view_mode == ''){
$this->listups($out);
if ($this->view_mode == 'edit'){
$this->editups($out, $this->id);
if ($this->view_mode == 'delete') {
$this->deleteups($this->id);
$this->redirect("?");
if ($this->view_mode == 'propertyes'){
$this->propertyes($out, $this->id);
switch ($this->view_mode){
case 'help':
$this->view_mode = "help";
break;
case '':
break;
* FrontEnd
* Module frontend
* @access public
function usual(&$out) {
$this->admin($out);
* List of ups
* Module frontend
* @access private
function listups(&$out) {
require(DIR_MODULES.$this->name.'/listups.inc.php');
* addconsole
* Module frontend
* @access private
function editups(&$out, $id){
require(DIR_MODULES.$this->name.'/edit.inc.php');
* deleteups
* Module frontend
* @access private
function deleteups($id) {
$rec=SQLSelectOne("SELECT * FROM app_nut_devices WHERE ID='$id'");
// some action for related tables
SQLExec("DELETE FROM app_nut_params WHERE DEVICEID='".$rec['ID']."'");
SQLExec("DELETE FROM app_nut_devices WHERE ID='".$rec['ID']."'");
* propertyes
* Module frontend
* @access private
function propertyes(&$out, $id){
require(DIR_MODULES.$this->name.'/propertyes.inc.php');
* Title
* Description
* @access public
function checkUPS() {
// Get checked ups
$upslist=SQLSelect("SELECT * FROM app_nut_devices WHERE CHECK_NEXT<=NOW()");
$total=count($upslist);
for($i=0;$i<$total;$i++) {
$ups=$upslist[$i];
$interval=$ups['INTERVAL'];
if (!$interval) {
$interval=60;
$ups['CHECK_NEXT']=date('Y-m-d H:i:s', time()+$interval);
SQLUpdate('app_nut_devices', $ups);
// Create
$nut = new nut_client($ups['UPS'], $ups['HOST'], $ups['PORT']);
// Connect
if ($nut->connect()){
// Login
if ($ups['USERNAME']) {
if (!$nut->login($ups['USERNAME'], $ups['PASSWORD'])){
DebMes("Error in nut connection: Error login");
// Get values
$change = false;
$params = $nut->listvar();
if ($params){
foreach ($params as $pname => $pval){
$prec=SQLSelectOne("SELECT * FROM app_nut_params WHERE DEVICEID='".$ups['ID']."' AND TITLE='".DBSafe($pname)."'");
if ($prec['ID']) {
if ($pval != $prec['VALUE']){
$prec['VALUE'] = $pval;
SQLUpdate('app_nut_params', $prec);
if ($prec['LINKED_OBJECT'] && $prec['LINKED_PROPERTY']) {
setGlobal($prec['LINKED_OBJECT'].'.'.$prec['LINKED_PROPERTY'], $prec['VALUE'], array($this->name=>'0'));
$change = true;
$ups['CHECK_LATEST']=date('Y-m-d H:i:s');
if ($change){
$params=array('VALUE'=>$params);
// do some status change actions
$run_script_id=0;
$run_code='';
// got online
if ($ups['SCRIPT_ID']) {
$run_script_id=$ups['SCRIPT_ID'];
} elseif ($ups['CODE']) {
$run_code=$ups['CODE'];
if ($run_script_id) {
//run script
runScript($run_script_id, $params);
} elseif ($run_code) {
//run code
try {
$code=$run_code;
$success=eval($code);
if ($success===false) {
DebMes("Error in NUT code: ".$code);
} catch(Exception $e){
DebMes('Error: exception '.get_class($e).', '.$e->getMessage().'.');
DebMes("Error in nut connection: ".$ups['HOST'].":".$ups['PORT']);
$nut = NULL;
* Control
* Module installation routine
* @access private
function control($alias, $cmd, $name = NULL, $val = NULL){
$ups=SQLSelectOne("SELECT * FROM app_nut_devices WHERE UPS='$alias'");
if ($ups['ID']) {
// Create
// Connect
// Login
switch ($cmd){
case 'upsdesc':
$res = $nut->upsdesc();
return $res;
case 'getvar':
$res = $nut->getvar($name);
return $res;
case 'vartype':
$res = $nut->vartype($name);
return $res;
case 'vardesc':
$res = $nut->vardesc($name);
return $res;
case 'varenum':
$res = $nut->varenum($name);
return $res;
case 'varrange':
$res = $nut->varrange($name);
return $res;
case 'cmddesc':
$res = $nut->cmddesc($name);
return $res;
case 'listups':
$res = $nut->listups();
return $res;
case 'listvar':
$res = $nut->listvar();
return $res;
case 'listrw':
$res = $nut->listrw();
return $res;
case 'listcmd':
$res = $nut->listcmd();
return $res;
case 'instcmd':
$res = $nut->instcmd($name);
return $res;
case 'setvar':
$res = $nut->setvar($name, $val);
return $res;
case 'master':
$res = $nut->master();
return $res;
case 'fsd':
$res = $nut->fsd();
return $res;
case 'starttls':
$res = $nut->starttls();
return $res;
case 'ver':
$res = $nut->ver();
return $res;
case 'netver':
$res = $nut->netver();
return $res;
$nut = NULL;
* Install
* @access private
function install() {
parent::install();
* dbInstall
* Database installation routine
* @access private
function dbInstall($data) {
app_nut_devices - Devices
app_nut_properties - Properties
$data = <<<EOD
app_nut_devices: ID int(10) unsigned NOT NULL auto_increment
app_nut_devices: HOST varchar(255) NOT NULL DEFAULT 'localhost'
app_nut_devices: PORT int(10) unsigned NOT NULL DEFAULT '3493'
app_nut_devices: UPS varchar(255) NOT NULL DEFAULT ''
app_nut_devices: USERNAME varchar(255) NOT NULL DEFAULT ''
app_nut_devices: PASSWORD varchar(255) NOT NULL DEFAULT ''
app_nut_devices: TITLE varchar(255) NOT NULL DEFAULT ''
app_nut_devices: CMDNOTE text NOT NULL DEFAULT ''
app_nut_devices: SCRIPT_ID int(10) NOT NULL DEFAULT '0'
app_nut_devices: CODE text
app_nut_devices: CHECK_LATEST datetime
app_nut_devices: CHECK_NEXT datetime
app_nut_devices: INTERVAL int(10) NOT NULL DEFAULT '0'
app_nut_params: ID int(10) unsigned NOT NULL auto_increment
app_nut_params: DEVICEID int(10) NOT NULL DEFAULT '0'
app_nut_params: TITLE varchar(255) NOT NULL DEFAULT ''
app_nut_params: NOTE varchar(255) NOT NULL DEFAULT ''
app_nut_params: VALUE varchar(255) NOT NULL DEFAULT ''
app_nut_params: LINKED_OBJECT varchar(255) NOT NULL DEFAULT ''
app_nut_params: LINKED_PROPERTY varchar(255) NOT NULL DEFAULT ''
EOD;
parent::dbInstall($data);
Notice: Undefined index: SERVER_NAME in /media/data/public_html/config.php on line 73
Notice: Undefined index: REQUEST_URI in /media/data/public_html/lib/loader.php on line 15
Notice: Undefined index: REQUEST_METHOD in /media/data/public_html/lib/general.class.php on line 53
Notice: Undefined index: REQUEST_METHOD in /media/data/public_html/lib/general.class.php on line 79
Notice: Undefined index: SERVER_ADDR in /media/data/public_html/load_settings.php on line 22
Notice: Undefined index: SERVER_PORT in /media/data/public_html/load_settings.php on line 22
* NUT
* @package project
* @author Ivan Z. <
[email protected]>
* @copyright
* Ver: 0.2
* blank
* @access private
$this->title="NUT";
* saveParams
* @access public
$p=array();
$p["id"]=$this->id;
* getParams
* @access public
global $id;
global $mode;
global $view_mode;
global $edit_mode;
global $tab;
if (isset($id)) {
$this->id=$id;
if (isset($mode)) {
$this->mode=$mode;
if (isset($tab)) {
$this->tab=$tab;
* Run
* Description
* @access public
function run() {
global $session;
$out=array();
$this->admin($out);
$this->usual($out);
$this->data=$out;
* BackEnd
* Module backend
* @access public
case 'help':
break;
case '':
break;
* FrontEnd
* Module frontend
* @access public
$this->admin($out);
* List of ups
* Module frontend
* @access private
* addconsole
* Module frontend
* @access private
* deleteups
* Module frontend
* @access private
* propertyes
* Module frontend
* @access private
* Title
* Description
* @access public
// Get checked ups
$ups=$upslist[$i];
if (!$interval) {
$interval=60;
// Create
// Connect
// Login
// Get values
$change = false;
if ($params){
if ($prec['ID']) {
$change = true;
if ($change){
$run_script_id=0;
$run_code='';
// got online
//run script
//run code
try {
$code=$run_code;
$nut = NULL;
* Control
* @access private
if ($ups['ID']) {
// Create
// Connect
// Login
switch ($cmd){
case 'upsdesc':
return $res;
case 'getvar':
return $res;
case 'vartype':
return $res;
case 'vardesc':
return $res;
case 'varenum':
return $res;
case 'varrange':
return $res;
case 'cmddesc':
return $res;
case 'listups':
return $res;
case 'listvar':
return $res;
case 'listrw':
return $res;
case 'listcmd':
return $res;
case 'instcmd':
return $res;
case 'setvar':
return $res;
case 'master':
return $res;
case 'fsd':
$res = $nut->fsd();
return $res;
case 'starttls':
return $res;
case 'ver':
$res = $nut->ver();
return $res;
case 'netver':
return $res;
$nut = NULL;
* Install
* @access private
parent::install();
* dbInstall
* @access private
$data = <<<EOD
EOD;
Fatal error: Class 'app_nut' not found in /media/data/public_html/scripts/cycle_nut.php on line 21
* NUT
* @package project
* @author Ivan Z. <
[email protected]>
* @copyright
* Ver: 0.2
* blank
* @access private
$this->title="NUT";
* saveParams
* @access public
$p=array();
$p["id"]=$this->id;
* getParams
* @access public
global $id;
global $mode;
global $view_mode;
global $edit_mode;
global $tab;
if (isset($id)) {
$this->id=$id;
if (isset($mode)) {
$this->mode=$mode;
if (isset($tab)) {
$this->tab=$tab;
* Run
* Description
* @access public
function run() {
global $session;
$out=array();
$this->admin($out);
$this->usual($out);
$this->data=$out;
* BackEnd
* Module backend
* @access public
case 'help':
break;
case '':
break;
* FrontEnd
* Module frontend
* @access public
$this->admin($out);
* List of ups
* Module frontend
* @access private
* addconsole
* Module frontend
* @access private
* deleteups
* Module frontend
* @access private
* propertyes
* Module frontend
* @access private
* Title
* Description
* @access public
// Get checked ups
$ups=$upslist[$i];
if (!$interval) {
$interval=60;
// Create
// Connect
// Login
// Get values
$change = false;
if ($params){
if ($prec['ID']) {
$change = true;
if ($change){
$run_script_id=0;
$run_code='';
// got online
//run script
//run code
try {
$code=$run_code;
$nut = NULL;
* Control
* @access private
if ($ups['ID']) {
// Create
// Connect
// Login
switch ($cmd){
case 'upsdesc':
return $res;
case 'getvar':
return $res;
case 'vartype':
return $res;
case 'vardesc':
return $res;
case 'varenum':
return $res;
case 'varrange':
return $res;
case 'cmddesc':
return $res;
case 'listups':
return $res;
case 'listvar':
return $res;
case 'listrw':
return $res;
case 'listcmd':
return $res;
case 'instcmd':
return $res;
case 'setvar':
return $res;
case 'master':
return $res;
case 'fsd':
$res = $nut->fsd();
return $res;
case 'starttls':
return $res;
case 'ver':
$res = $nut->ver();
return $res;
case 'netver':
return $res;
$nut = NULL;
* Install
* @access private
parent::install();
* dbInstall
* @access private
$data = <<<EOD
EOD;
* NUT
* @package project
* @author Ivan Z. <
[email protected]>
* @copyright
* Ver: 0.2
* blank
* @access private
$this->title="NUT";
* saveParams
* @access public
$p=array();
$p["id"]=$this->id;
* getParams
* @access public
global $id;
global $mode;
global $view_mode;
global $edit_mode;
global $tab;
if (isset($id)) {
$this->id=$id;
if (isset($mode)) {
$this->mode=$mode;
if (isset($tab)) {
$this->tab=$tab;
* Run
* Description
* @access public
function run() {
global $session;
$out=array();
$this->admin($out);
$this->usual($out);
$this->data=$out;
* BackEnd
* Module backend
* @access public
case 'help':
break;
case '':
break;
* FrontEnd
* Module frontend
* @access public
$this->admin($out);
* List of ups
* Module frontend
* @access private
* addconsole
* Module frontend
* @access private
* deleteups
* Module frontend
* @access private
* propertyes
* Module frontend
* @access private
* Title
* Description
* @access public
// Get checked ups
$ups=$upslist[$i];
if (!$interval) {
$interval=60;
// Create
// Connect
// Login
// Get values
$change = false;
if ($params){
if ($prec['ID']) {
$change = true;
if ($change){
$run_script_id=0;
$run_code='';
// got online
//run script
//run code
try {
$code=$run_code;
$nut = NULL;
* Control
* @access private
if ($ups['ID']) {
// Create
// Connect
// Login
switch ($cmd){
case 'upsdesc':
return $res;
case 'getvar':
return $res;
case 'vartype':
return $res;
case 'vardesc':
return $res;
case 'varenum':
return $res;
case 'varrange':
return $res;
case 'cmddesc':
return $res;
case 'listups':
return $res;
case 'listvar':
return $res;
case 'listrw':
return $res;
case 'listcmd':
return $res;
case 'instcmd':
return $res;
case 'setvar':
return $res;
case 'master':
return $res;
case 'fsd':
$res = $nut->fsd();
return $res;
case 'starttls':
return $res;
case 'ver':
$res = $nut->ver();
return $res;
case 'netver':
return $res;
$nut = NULL;
* Install
* @access private
parent::install();
* dbInstall
* @access private
$data = <<<EOD
EOD;
* NUT
* @package project
* @author Ivan Z. <
[email protected]>
* @copyright
* Ver: 0.2
* blank
* @access private
$this->title="NUT";
* saveParams
* @access public
$p=array();
$p["id"]=$this->id;
* getParams
* @access public
global $id;
global $mode;
global $view_mode;
global $edit_mode;
global $tab;
if (isset($id)) {
$this->id=$id;
if (isset($mode)) {
$this->mode=$mode;
if (isset($tab)) {
$this->tab=$tab;
* Run
* Description
* @access public
function run() {
global $session;
$out=array();
$this->admin($out);
$this->usual($out);
$this->data=$out;
* BackEnd
* Module backend
* @access public
case 'help':
break;
case '':
break;
* FrontEnd
* Module frontend
* @access public
$this->admin($out);
* List of ups
* Module frontend
* @access private
* addconsole
* Module frontend
* @access private
* deleteups
* Module frontend
* @access private
* propertyes
* Module frontend
* @access private
* Title
* Description
* @access public
// Get checked ups
$ups=$upslist[$i];
if (!$interval) {
$interval=60;
// Create
// Connect
// Login
// Get values
$change = false;
if ($params){
if ($prec['ID']) {
$change = true;
if ($change){
$run_script_id=0;
$run_code='';
// got online
//run script
//run code
try {
$code=$run_code;
$nut = NULL;
* Control
* @access private
if ($ups['ID']) {
// Create
// Connect
// Login
switch ($cmd){
case 'upsdesc':
return $res;
case 'getvar':
return $res;
case 'vartype':
return $res;
case 'vardesc':
return $res;
case 'varenum':
return $res;
case 'varrange':
return $res;
case 'cmddesc':
return $res;
case 'listups':
return $res;
case 'listvar':
return $res;
case 'listrw':
return $res;
case 'listcmd':
return $res;
case 'instcmd':
return $res;
case 'setvar':
return $res;
case 'master':
return $res;
case 'fsd':
$res = $nut->fsd();
return $res;
case 'starttls':
return $res;
case 'ver':
$res = $nut->ver();
return $res;
case 'netver':
return $res;
$nut = NULL;
* Install
* @access private
parent::install();
* dbInstall
* @access private
$data = <<<EOD
EOD;
* NUT
* @package project
* @author Ivan Z. <
[email protected]>
* @copyright
* Ver: 0.2
* blank
* @access private
$this->title="NUT";
* saveParams
* @access public
$p=array();
$p["id"]=$this->id;
* getParams
* @access public
global $id;
global $mode;
global $view_mode;
global $edit_mode;
global $tab;
if (isset($id)) {
$this->id=$id;
if (isset($mode)) {
$this->mode=$mode;
if (isset($tab)) {
$this->tab=$tab;
* Run
* Description
* @access public
function run() {
global $session;
$out=array();
$this->admin($out);
$this->usual($out);
$this->data=$out;
* BackEnd
* Module backend
* @access public
case 'help':
break;
case '':
break;
* FrontEnd
* Module frontend
* @access public
$this->admin($out);
* List of ups
* Module frontend
* @access private
* addconsole
* Module frontend
* @access private
* deleteups
* Module frontend
* @access private
* propertyes
* Module frontend
* @access private
* Title
* Description
* @access public
// Get checked ups
$ups=$upslist[$i];
if (!$interval) {
$interval=60;
// Create
// Connect
// Login
// Get values
$change = false;
if ($params){
if ($prec['ID']) {
$change = true;
if ($change){
$run_script_id=0;
$run_code='';
// got online
//run script
//run code
try {
$code=$run_code;
$nut = NULL;
* Control
* @access private
if ($ups['ID']) {
// Create
// Connect
// Login
switch ($cmd){
case 'upsdesc':
return $res;
case 'getvar':
return $res;
case 'vartype':
return $res;
case 'vardesc':
return $res;
case 'varenum':
return $res;
case 'varrange':
return $res;
case 'cmddesc':
return $res;
case 'listups':
return $res;
case 'listvar':
return $res;
case 'listrw':
return $res;
case 'listcmd':
return $res;
case 'instcmd':
return $res;
case 'setvar':
return $res;
case 'master':
return $res;
case 'fsd':
$res = $nut->fsd();
return $res;
case 'starttls':
return $res;
case 'ver':
$res = $nut->ver();
return $res;
case 'netver':
return $res;
$nut = NULL;
* Install
* @access private
parent::install();
* dbInstall
* @access private
$data = <<<EOD
EOD;
